  3. OBIS Code Description
OBIS code description
Profile picture for user batulzii
By batulzii , 18 January, 2024
i plan to add more registers with obis/ln.
but here is description unmatched.
batulzii
2 years 10 months ago
Hello, 1.8.0 -- Positive…
1.8.0 -- Positive active energy, total?
ln -- 1.1.8.0.0.255 - correct?
Hi, 1.1.8.0.0.255 is Ch. 1…
1.1.8.0.0.255 is Ch. 1 Sum Li Reactive power QIV Billing period avg.
You can find correct OBIS code with GuruxDLMSTranslator.
https://www.gurux.fi/GuruxDLMSTranslator
Select OBIS code tab. Clear the OBIS code and set e.g. "active energy" to the filter. Press search and you can see possible options. Select OBIS code that you want to use.
batulzii
Hello Kurumi, There is no…
Hello Kurumi,
There is no such window. Mine is like attached. Separate OBIS code window, but it does not have search button
BR
Hi, I'm sorry. I mean…
I'm sorry. I mean GuruxDLMSTranslator, not GXDLMSDirector. Try this link.
batulzii
Hello, But Description has…
But Description has different meaning. 1.0.1.8.0255 should be active energy, DLMSdirectүж shows Sum Li Active Power ...
Hi, OBIS descriptions are…
OBIS descriptions are coming from DLMS standards.
1.0.1.8.0.255 is Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
You need to select a different OBIS code for active energy.
  • Victorian | WA 083148835648
  • JOBS Billiard (Jakarta Online Billiard Store) | WA 083148835648
