  3. Activity Calendar
activity calendar
Profile picture for user batulzii
By batulzii , 15 January, 2024
Nordic server was added activity calendar and register activation, and script too. DLMSDirector can check defaults. changed active tariff #, but it could not trigger by server itself. and debugger unexpecdetly exited when breakpointed over svr_handleActivityCalendar function.
batulzii
2 years 9 months ago
Hi, reason why debugger…
reason why debugger halted is i used threads.
batulzii
Did you have adopted activity calendar in Nordic server?
Hi, Is it possible that you…
Is it possible that you don't use threads? ANSI C is not thread-safe and support for threads is not implemented because our clients are using so many compilers.
You can use the activity calendar with Nordic as with all other compilers.
https://github.com/Gurux/GuruxDLMS.c/blob/5fcc54cf1f79701d198675ef22c95…
batulzii
Hello, Got it. svr_run() was…
Got it. svr_run() was out from thread. How to use indexes in Register Activation? several registers for tariff. reading metrics and updating registers, but how is best using register activation indexes for it?
