  3. DLMS Meter Listener Is Not Connecting With Client
DLMS Meter Listener is not connecting with Client
By Charan , 9 January, 2024
we are trying to connect energy meter with gurux dll to establish connection and to read the DLMS electricity meter. we have tried with DLMS Listener source code.
To the server we have sent parameters as TCP and Port number, due to wrong port number it gave errors initially but once the right parameters were passed, status of server.Open() updated to True.
But Client connection is not establishing, OnClientConnected method event is not getting called and facing problems regarding it.
We need to connect & read the data from the DLMS electricity meters.
Thankyou,
2 years 9 months ago
Hi, Is your meter sending…
Is your meter sending the push messages or is using auto-connect and the meter is establishing the connection for the server?
Read your meter with GXDLMSDirector and check if auto-connect is available.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSAutoConnect
If your meter is sending push messages you need to use push listener example.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Push.Lis…
Charan
tried sending readmeter…
tried sending
readmeter(server);
readmeter tried transmitting AARQ request as in the screenshot, but no response from meter.
Charan
Trying with Push.listner…
Trying with Push.listner code, but GXDLMSSecureNotify is giving missing assembly error. which dll is required for this.
Charan
Hi, Please, don't add hex…
Please, don't add hex pics. They are hard to read. Plain text is better.
I believe that one of your meter settings is different what the meter expects. Check first the server and client address. They are usually the reason.
Visual studio should update all assemblies. What error you are getting?
Charan
Hi Mikko, I have tried with…
I have tried with push.listener code, I recieved the console output as below:
Listening DLMS Push IEC 62056-47 messages on port 4059.
Press X to close and Enter to send a Push message.
Sending Push message.
Client Connected.
Client Connected.
<- 00 01 00 01 00 0A 00 16 0F C0 00 00 02 00 02 01 09 0C 07 E8 01 09 FF 10 0F 0B FF FE B6 00
Client Disconnected.
Client Connected.
<- 00 01 00 01 00 0A 00 16 0F C0 00 00 03 00 02 01 09 0C 07 E8 01 09 FF 10 17 35 FF FE B6 00
Client Connected.
<- 00 01 00 01 00 0A 00 16 0F C0 00 00 04 00 02 01 09 0C 07 E8 01 09 FF 10 18 28 FF FE B6 00
Client Connected.
<- 00 01 00 01 00 0A 00 16 0F C0 00 00 05 00 02 01 09 0C 07 E8 01 09 FF 10 19 30 FF FE B6 00
the above things meant data from the meter? Does it mean its connected? Can you please let me know?
Charan
Hi, I believe you have…
I believe you have pressed enter when the push listener client sends an example message that is shown in the command line.
In the log, it looks like your meter has not established the connection for the server.
Can you read your meter with GXDLMSDirector? You can see the correct port and other settings if you can do it. Without this information, I can't help you. Can your meter establish the connection for your PC? Check that you don't have firewalls, etc.
Charan
Thanks for your response,…
Thanks for your response, Mikko.
In Meter.Listener code, inside try block, server.open() status turning into true once I gave correct details as below, but why OnClientConnected method is not getting called in debug mode? Why is this event not firing? How will I know client is connected with out entering into this method?
try
GXNet server = new GXNet(NetworkType.Tcp, "localhost", 4059);
server.Open();  Turned to True
server.OnClientConnected += OnClientConnected;(not going inside the OnClientConnected Method)
Can you please help me with why this method is not getting called, not entering inside it?
Hi, Your meter hasn't…
Your meter hasn't established the connection for the server.
Check if your meter supports auto-connect and then check that you have set the correct hostname and TCP/IP port number.
