  3. TCP Wrapper Is Not Working DLMS Client Example -ANSI C
TCP Wrapper is not working DLMS client example -ANSI C
By Mohanraj , 3 January, 2024
DLMS connection is success in DLMS Gurux Explorer with US mode on TCP Wrapper and below is the TX and RX log.
Log from Gurux DLMS Explorer - Connection on US and TCP wrapper
TX: 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF
RX: 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 58 00 07
TX: 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 2B 01 03 FF 02 00
RX: 00 01 00 01 00 10 00 09 C4 01 C1 00 06 00 00 00 F4
TX: 00 01 00 10 00 01 00 05 62 03 80 01 00
RX: 00 01 00 01 00 10 00 05 63 03 80 01 00
TX: 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 4C 54 43 4C 49 45 4E 54 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 30 21 43 4A 5A 29 4B 48 5D 0E 1F 27 24 15 0E 55 BE 23 04 21 21 1F 30 00 00 00 F5 09 B7 82 44 4E 6D 10 A5 E6 1C 5F 8D D9 C0 9B DC 9C 30 A6 70 28 85 A0 97 42 2A
RX: 00 01 00 01 00 30 00 6B 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 33 00 23 1E A1 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 00 D7 02 F6 61 1D E2 A1 64 B2 28 53 6E 80 9D BE C0 41 32 0A BE BC 99 53 F8 12 1D 31
TX: 00 01 00 30 00 01 00 32 CB 30 30 00 00 00 F6 89 82 0C 1E 69 09 9C 77 6E 36 C0 93 D8 8D 12 CD C6 7A 18 BF B7 C5 80 28 FB 16 16 BF 3A 7C 77 D9 DE 29 C3 7C 7E A0 17 29 D0 4D 6C
RX: 00 01 00 01 00 30 00 2B CF 29 30 00 00 00 D8 45 1E 7E 73 42 82 62 5A 5D 37 92 6E EB 59 A7 B6 C8 2C B6 36 D5 85 23 AF 3F A2 5E B2 39 9A 59 71 D7 7C 3C C0
Where as with the DLMS Client Example in linux Tx and Rx logs are different and it is not moving to next level and below is the log and it is struck everytime at the same place.
Running the command as below
bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -i WRAPPER -c 48 -a High -P ABCDEFGH12345678 -C AuthenticationEncryption -T 4C54434C49454E54 -A 31323334353637383930313233343536 -B 31323334353637383930313233343536 -v 0.0.43.1.3.255 -V Suite0 -s 1 -r ln -t Verbose
TX: 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF
RX: 00 01 00 01 00 10 00 09 C4 01 C1 00 06 00 00 00 FB
Invocation counter: 252 (0xFC)
InitializeConnection
TX: 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 4C 54 43 4C 49 45 4E 54 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 00 00 00 FC C5 B6 F9 14 64 F8 59 0E 61 75 E0 20 C1 C6 55 56 05 73 2C C7 7A 56 4C 55 67 70
AARQRequest failed Data receive failed.
What is an issue with DLMS TCP wrapper stack?
Note :
1.using latest stack
2.With the same credentials DLMS explorer is working
2 years 10 months ago
Hi, You have removed Action…
You have removed Action from conformance flags. You need to add DLMS_CONFORMANCE_ACCESS back to the proposed conformance.
Mohanraj
Hi Mikko, How to add DLMS…
How to add DLMS_CONFORMANCE_ACCESS ? because we are using Client example linux code.
Mohanraj
Hi Mohanraj, You have made…
Hi Mohanraj,
You have made some changes to the source code because DLMS_CONFORMANCE_ACCESS is set as default. Remove your changes.
Mohanraj
Hi Mikko, We haven't…
We haven't modified any code. We have downloaded latest source from github and just have compiled Client example program and running it.
So where do you think is the problem?
The way we are running the program is via the command is below
Mohanraj
