  3. Power Meter Integration Using DLMS Protocol
By Chetna , 28 November, 2023
Payload sample shared by one of the Power Meter OEMs.
Will gurux libraries (default or advanced) will be able to read this sample payload? if yes, which libraries and sample code can be used?
Payload Sample :
00 01 00 01 00 05 00 AF C2 01 0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 00 28 00 09 16 09 00 FF 02 19 09 0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 04 28 E6 00 03 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 05 00 00 27 10 12 13 8B 06 00 00 00 00 06 00 05 1E D9 05 00 00 27 10 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 06 00 05 1E D9 06 00 00 00 00 06 00 05 1E D9
Data Analysis -
00 01 00 01 00 05 00 AF //Wripper head
C2 //Event notification
01 //clock indicate
0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 //clock
00 28 00 09 16 09 00 FF //Push instance profile obis
02 19 //Structure with 25 element
09 0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 //Current date/time
04 28 E6 00 03 00 00 //Status Information
15 00 00 00 00 00 00 00 00 //∑Li Import active energy (QI+QIV)
15 00 00 00 00 00 00 00 00 //∑Li Export active energy (QII+QIII)
15 00 00 00 00 00 00 00 00 //∑Li Import apparent energy (QI+QIV)
15 00 00 00 00 00 00 00 00 //∑Li Export apparent energy (QII+QIII)
06 00 00 00 00 //∑Li Instantaneous import active power (QI+QIV)
06 00 00 00 00 //∑Li Instantaneous export active power (QII+QIII)
06 00 00 00 00 //∑Li Instantaneous import apparent power (QI+QIV)
06 00 00 00 00 //∑Li Instantaneous export apparent power (QII+QIII)
05 00 00 27 10 //∑Li Instantaneous import power factor
05 00 00 27 10 //∑Li Instantaneous export power factor
12 13 8B //Instantaneous supply frequency
06 00 00 00 00 //L1 Instantaneous current
06 00 05 1E D9 //L1 Instantaneous voltage
05 00 00 27 10 //L1 Instantaneous import power factor
06 00 00 00 00 //L2 Instantaneous current
06 00 00 00 00 //L2 Instantaneous voltage
05 00 00 27 10 //L2 Instantaneous import power factor
06 00 00 00 00 //L3 Instantaneous current
06 00 00 00 00 //L3 Instantaneous voltage
05 00 00 27 10 //Instantaneous import power factor
06 00 05 1E D9 //L1-L2 Instantaneous voltage
06 00 00 00 00 //L2-L3 Instantaneous voltage
06 00 05 1E D9 //L3-L1 Instantaneous voltage
2 years 11 months ago
Hi, The meter sends an…
The meter sends an invalid event notification. The attribute-id is missing from Cosem-Attribute-Descriptor. You need to ask meter manufacturer to fix this.
00 28
00 09 16 09 00 FF
02 //attribute-id is MISSING
