  3. DLMS IEC62053-26 Protocol How To Retrieve Previous Month's Data? (obis Code)
DLMS IEC62053-26 protocol how to retrieve previous month's data? (obis code)
Profile picture for user Zaya
By Zaya , 3 November, 2023
I have been trying to get previous month's data of my three phase smart meter and I do not understand 1.8.1*X obis code. Please help me how to get the X value.
Thank you.
3 years ago
Hi, I believe that it's…
I believe that it's easiest if you download GXDLMSDirector and play with that. It will help to understand DLMS devices and what you can do with them.
Zaya
3 years ago
Hello Thank you for your…
Hello
Thank you for your reply, I did try GXDLMSDirector and the meter I am using is not in the manufacturer list and I added the manufacturer but I still get "no connection could be made because the target machine actively refused it" error. Also I am trying to connect using third party device which is RS485 interface. Is it possible?
Any advice on this?
Thank you.
3 years ago
Hi, Yes, that is possible. …
Yes, that is possible. "no connection could be made because the target machine actively refused it" error means that your IP address or port number is wrong and TCP/IP connection can't be established. Check those first.
Zaya
3 years ago
The meter I am using is…
The meter I am using is Shenzhen Inhemeter i310(DTZ1513) and I am using serial port to connect and still does not work I am not sure it's settings or not. Can you check this meter?
3 years ago
Hi, We don't have DTZ1513…
We don't have DTZ1513 meter. I believe that one of your settings is different than the meter expects. You need to check the correct settings from the meter documentation or contact the meter vendor.
Zaya
3 years ago
Thank you for your advice…
Thank you for your advice sir. Is there any chance to talk to you via email or social media that I can ask you a few more things?
3 years ago
Hi, I'm sorry, but we can…
I'm sorry, but we can help only our clients by email.
