  3. Getting Disconnect Request While Run GuruxDLMSPython
Getting disconnect request while run GuruxDLMSPython
By sankar@gurux , 6 October, 2023
by providing following request from command line
C:\Users\fsn3kor\PycharmProjects\Smart_Meter\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python>python main.py -S COM9 -g 0.0.1.0.0.255:2 -c 48 -a High -P 0JK0CRSM01007488 -C AuthenticationEncryption -T 4C54434C49454E54 -A 31323334353637383930313233343536 -B 31323334353637383930313233343536 -v 0.0.43.1.3.255 -d India -w 1 -f 128 -t Verbose -o C:\\device.xml
Observed below response ,what might be the issue here
gurux_dlms version: 1.0.140
gurux_net version: 1.0.20
gurux_serial version: 1.0.20
Authentication: 2
ClientAddress: 0x30
Standard: 1
Security: 48
System title: 4C 54 43 4C 49 45 4E 54
Authentication key: 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36
Block cipher key: 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36
TX: 18:31:48 7E A0 07 03 21 93 0F 01 7E
RX: 18:31:48 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 18:31:48 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF 91 23 7E
RX: 18:31:48 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 03 0C 00 07 04 53 7E
TX: 18:31:48 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 03 FF 02 00 B0 AA 7E
RX: 18:31:48 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 05 CD 2C 7B 7E
Invocation counter: 1486
TX: 18:31:48 7E A0 07 03 21 53 03 C7 7E
TX: 18:31:48 7E A0 07 03 61 93 69 47 7E
RX: 18:31:49 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 18:31:49 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 4C 54 43 4C 49 45 4E 54 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 D7 9D 52 65 2D F6 4A 44 67 32 5F A6 C6 8B 26 A8 BE 23 04 21 21 1F 30 00 00 05 CE 52 49 2C C8 6C 8C BF F2 AA 57 50 D7 5F 19 0D 52 F0 0E 75 70 23 4D B7 1F E0 99 40 B6 7E
RX: 18:31:49 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 41 00 23 1C EB 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 04 2B C5 CE B0 33 87 77 37 09 60 CC B1 54 8F 30 17 A1 9C C9 2D 22 CE 98 AF F3 9D BE E9 85 7E
TX: 18:31:49 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 00 00 05 CE 90 48 ED C8 65 D3 A0 DE AA 17 B1 8B 5D 1C 40 C4 68 B5 D1 56 4F D4 26 70 D1 C1 45 ED B6 96 B9 C0 CB 06 60 17 37 7C 7F D4 BE 1C 37 BE 0B 7E
RX: 18:31:54 7E A0 07 61 03 51 67 44 7E
Server did not accept CtoS.
File "C:\Users\fsn3kor\PycharmProjects\Smart_Meter\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\main.py", line 92, in main
reader.initializeConnection()
File "C:\Users\fsn3kor\PycharmProjects\Smart_Meter\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 319, in initializeConnection
self.client.parseApplicationAssociationResponse(reply.data)
File "C:\Users\fsn3kor\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\GXDLMSClient.py", line 667, in parseApplicationAssociationResponse
raise Exception("parseApplicationAssociationResponse failed. " + " Server to Client do not match.")
Exception: parseApplicationAssociationResponse failed. Server to Client do not match.
3 years 1 month ago
Hi, Check your password. The…
Check your password. The meter should reply error if the password is invalid, but the meter doesn't reply.
sankar@gurux
3 years ago
Hi , The PW i'm using is -P…
Hi ,
The PW i'm using is -P 0JK0CRSM01007488, same thing is able to read from GXDLMS director.
But through python im still facing above error,could you please help on this ?
3 years ago
Hi, Update gurux_dlms to the…
Update gurux_dlms to the latest version (1.0.146). There is one update that might solve your problem.
sankar@gurux
2 years 12 months ago
Hi Kurumi, Thanks for the…
Hi Kurumi,
Thanks for the response.
I have updated the gurux_dlms,but i didn't see any difference in the response.
C:\Users\fsn3kor\PycharmProjects\DLMS_Python\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python>python main.py -S COM9 -g 0.0.1.0.0.255:2 -c 48 -a High -P 0BE04BCM01008219 -C AuthenticationEncryption -T 4C54434C49454E54 -A 31323334353637383930313233343536 -B 31323334353637383930313233343536 -v 0.0.43.1.3.255 -d India -w 1 -f 128 -t Verbose
Authentication: 2
ClientAddress: 0x30
Standard: 1
Security: 48
TX: 12:06:36 7E A0 07 03 21 93 0F 01 7E
RX: 12:06:36 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 12:06:36 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF 91 23 7E
RX: 12:06:37 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 05 DC 00 07 91 97 7E
TX: 12:06:37 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 03 FF 02 00 B0 AA 7E
RX: 12:06:37 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 02 1A 16 94 7E
Invocation counter: 539
TX: 12:06:37 7E A0 07 03 21 53 03 C7 7E
RX: 12:06:37 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 12:06:37 7E A0 07 03 61 93 69 47 7E
RX: 12:06:37 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 12:06:37 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 4C 54 43 4C 49 45 4E 54 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 1E BC AA 3E D4 FF F8 8E 2E 17 05 74 00 1B 70 50 BE 23 04 21 21 1F 30 00 00 02 1B 5D C5 AA 06 49 41 17 FE A9 38 73 0C 89 47 A4 F4 92 8E 5B CB C9 B3 D6 39 CA 1D 08 50 7E
RX: 12:06:37 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 00 01 EC E0 5D 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 53 45 49 50 4C 2D 4C 54 45 41 2D 49 4E 44 49 41 BE 23 04 21 28 1F 30 00 00 01 E6 14 7A CC 0C 6C 34 4E 2B 13 62 D8 59 A4 F6 7D BE 27 DD 13 A7 F0 6B 0F CD 4D F6 AB 9E 7E
TX: 12:06:37 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 00 00 02 1B 9F C4 6B 06 40 1E 08 D2 A9 78 92 50 8D 92 7D 08 EB 45 BB 1A A0 79 67 27 08 81 5E EA 49 E6 23 CD B7 D5 7F D7 A2 06 72 8E D9 66 22 CB DF 7E
RX: 12:06:42 7E A0 07 61 03 51 67 44 7E
File "C:\Users\fsn3kor\PycharmProjects\DLMS_Python\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\main.py", line 92, in main
File "C:\Users\fsn3kor\PycharmProjects\DLMS_Python\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 318, in initializeConnection
2 years 11 months ago
Hi, You are still using…
You are still using gurux_dlms version: 1.0.140, not 1.0.146
You can update all versions running:
pip install -r requirements.txt --upgrade
