  3. DateTime Epoch Conversion
DateTime epoch conversion
By Bhaumik , 26 September, 2023
We have extracted the block load profile data and acquired the accurate date and time for 15-minute block intervals in GXDLMDirector. For example:
26/09/2023 00:15:00
26/09/2023 00:30:00
However, when utilizing the ToUnixTime function from the GXDateTime object to convert time to epoch and back to regular time, we are encountering the following discrepancies:
DateTime dateTime = new DateTime(1970, 1, 1, 0, 0, 1, DateTimeKind.Utc);
return Convert.ToInt64((date.ToUniversalTime() - dateTime).TotalSeconds);
26/09/2023 00:14:59
26/09/2023 00:29:59
Could you kindly provide your recommendations on how we can obtain the correct datetime from epoch in DLMS? and which one is correct ?
3 years 1 month ago
Hi, The correct EPOC time is…
The correct EPOC time is this.
DateTime dateTime = new DateTime(1970, 1, 1, 0, 0, 0, DateTimeKind.Utc);
You need to change seconds from 1 to zero.
