  3. No Data With Cl_readList() Response
No data with cl_readList() response
By tfo_develco , 30 August, 2023
I'm trying to read a list of register with cl_readList (GuruxDLMS.c). I based my function on the GuruxDLMSClientExample. The reply from the meter is:
PDU: c403c1040104010401040104
<GetResponse>
<GetResponseWithList>
<!--Priority: HIGH ServiceClass: CONFIRMED invokeID: 1-->
<Result Qty="04" >
</Result>
</GetResponseWithList>
</GetResponse>
So appearently no actually register data and reply_isMoreData(&reply) is false.
What am I missing? (I'm using HighGMAC authentication.)
BR, Thomas Fogh
static DLMS_ERROR_CODE ReadRegisters(void)
gxArray list;
message messages;
gxReplyData reply;
DLMS_ERROR_CODE ret = DLMS_ERROR_CODE_OK;
gxByteBuffer bb, rr;
gxDataInfo info;
dlmsVARIANT value;
ESP_LOGD(METER_TAG, "ReadRegisters");
arr_init(&list);
arr_push(&list, key_init("0.1.96.8.0.255", (void *)2)); // Ch. 1 Time of operation, total
arr_push(&list, key_init("1.1.14.7.0.255", (void *)2)); // Ch. 1 Supply frequency Inst. value
arr_push(&list, key_init("1.1.13.7.0.255", (void *)2)); // Ch. 1 Sum Li Power factor Inst. value
arr_push(&list, key_init("1.1.32.7.0.255", (void *)2)); // Ch. 1 L1 Voltage Inst. value
mes_init(&messages);
if ((ret = cl_readList(&mvDlmsSettings, &list, &messages)) != 0)
ESP_LOGE(METER_TAG, "ReadList failed %s", hlp_getErrorMessage(ret));
else
uint8_t pos;
reply_init(&reply);
// NOTE! Set ignore value to true because list is parsed differently than normal read.
reply.ignoreValue = 1;
BYTE_BUFFER_INIT(&rr);
BYTE_BUFFER_INIT(&bb);
// Send data.
for (pos = 0; pos != messages.size; ++pos)
// Send data.
reply_clear(&reply);
if ((ret = HandleDLMSPacket(messages.data[pos], &reply)) != DLMS_ERROR_CODE_OK)
ESP_LOGE(METER_TAG, "HandleDLMSPacket failed %s", hlp_getErrorMessage(ret));
break;
// Check is there errors or more data from server
while (reply_isMoreData(&reply))
ESP_LOGD(METER_TAG, "reply_isMoreData");
//mvDlmsSettings.cipher.invocationCounter = ++invocationCounter;
if ((ret = cl_receiverReady(&mvDlmsSettings, reply.moreData, &rr)) != DLMS_ERROR_CODE_OK ||
(ret = HandleDLMSPacket(&rr, &reply)) != DLMS_ERROR_CODE_OK)
ESP_LOGE(METER_TAG, "MoreData HandleDLMSPacket failed %s", hlp_getErrorMessage(ret));
break;
bb_clear(&rr);
bb_set2(&bb, &reply.data, reply.data.position, -1);
if (ret == 0)
ESP_LOGD(METER_TAG, "bb.size: %u", bb.size);
bb_clear(&bb);
bb_clear(&rr);
mes_clear(&messages);
arr_clear(&list);
return ret;
3 years 2 months ago
Hi, You need to add COSEM…
You need to add COSEM object for the list, not the OBIS codes.
Something like this:
gxRegister r1, r2;
cosem_init(BASE(r1), DLMS_OBJECT_TYPE_REGISTER, "0.1.96.8.0.255");
cosem_init(BASE(r2), DLMS_OBJECT_TYPE_REGISTER, "1.1.14.7.0.255");
arr_init(&list);
arr_push(&list, key_init(BASE(r1), (void *)2)); // Ch. 1 Time of operation, total
arr_push(&list, key_init(BASE(r2), (void *)2)); // Ch. 1 Supply frequency Inst.
tfo_develco
Hi Mikko, It's working now. …
It's working now. :)
Thanks!
BR, Thomas
