  3. Gurux.DLMS.Client.Example.Delphi Problem
Gurux.DLMS.Client.Example.Delphi problem
By Leo , 9 June, 2023
Hello, dear developer!
I'm using you test program and found an exception in procedure:
TGXProgram.ReadScalerAndUnits
During debugging, I noticed that FreeAndNil(list) instruction is called when list=nil
This corrupts the data in the variable tmp, so the code below is executing with an exception
My opinion is to move FreeAndNil(list) after
if list.Count <> 0 Then
ReadList(list);
where list variable is not nil
3 years 5 months ago
Hi, Thank you for this…
Thank you for this information and for reporting it. Your idea is good and it's added for the client example during next week.
