  3. Unable To Connect - Unhandled Exception.
Unable to connect - Unhandled exception.
Profile picture for user tukur
By tukur , 31 May, 2023
Gurux.DLMS.AMI
I'm getting this error when I try to run a docker container after I updated to the latest docker image
3 years 5 months ago
Hi, Please, don't add pics…
Please, don't add pics. Plain text is better to read.
Your MySQL server is not available. Check the host name.
tukur
Hi @Kurumi, MySql server is…
Hi @Kurumi,
MySql server is up and running. I created a new user with all privileges, Yet I can't access the app. I'm using docker
Hi, This is a clear MySQL…
This is a clear MySQL connection error. I try with empty MySQL and get the latest docker. It starts to work without problems.
Try to install MySQL client for the docker.
Open docker using the terminal and run this.
apt-get update && apt-get install -y default-mysql-client
Then try to connect to your MySQL DB.
mysql -h YOUR_HOST_NAME -u USER_NAME -p
I believe that you get the same error message.
Check also the firewall.
