  3. Push Listener Python
By kevin jose minj , 30 May, 2023
when I am run this python push listener example I am getting this data. Why I am not receiving the exact hexadecimaldata?
COM3:9600 8NONE1
Press any key to close the application.
Media state changed. MediaState.OPENING
trace:12:56:47 TraceTypes.INFO Settings: Port: COM3 Baud Rate: BaudRate.BAUD_RATE_9600 Data Bits: 8 Parity: Parity.NONE Stop Bits: StopBits.ONE Eop:126
New data is received. COM3:00
3 years 5 months ago
Hi, You need to change the…
You need to change the trace type from info to Verbose.
kevin jose minj
I changed the trace type to…
I changed the trace type to Verbose and this is command I am now
python main.py -S COM3 -t Verbose
I am getting the same output
COM3:9600 8NONE1
trace:14:53:17 TraceTypes.RECEIVED 00
trace:14:53:18 TraceTypes.RECEIVED 00
kevin jose minj
I have question regarding…
I have question regarding with push listener. Is there any way to get data from simulated meters to test the push listener example?
Please help me out
Hi, I just realized that the…
I just realized that the Python example doesn't add the hex trace for the output.
Simulators can't send push messages at this moment. You can only read them.
kevin jose minj
So is there any issue with…
So is there any issue with python push listener example?
Hi, No, there is no issue…
No, there is no issue. The example just doesn't add the hex trace.
kevin jose minj
Hi Mikko, But , I added -t…
But , I added -t Verbose parameter. Why its not giving the hex trace ?
Hi, Get the latest version…
Get the latest version from the push example. It will add a hex trace if verbose argument is added,
