  2. Authentication Failure
Authentication failure
By kevin jose minj , 4 May, 2023
When I try to connect the meter using US password same used in gurux director using python it is failing? What causes this issue? Given below the parameters I used.
['-S', 'COM5', '-c', '48', '-a', 'High', '-P', '000000000000000000000000 00000000', '-C', 'AuthenticationEncryption', '-T', '4D52543030303031', '-A', '556E69636173744B579484C53303031', '-B', '556E69636173744B579484C53303031', '-o', 'device.xml', '-t', 'Verbose', '-d', 'India', '-s', '16640']
3 years 1 month ago
Hi, I believe that your…
I believe that your password is in hex format. You need to add 0x and remove space.
