  3. ReadObject Failed Register 1.0.1.7.0.255:2 Not Enough Memory Available
ReadObject failed Register 1.0.1.7.0.255:2 Not enough memory available
By Prakash , 28 December, 2022
Every 5 secs, we read 6 registers from dlms meter (from L&T). Occasionally we
get "Not enough memory available" error:
If I close connection, com port and open again, it works. And then error
repeats after some time.
I also made following change in the code:
con_initializeBuffers(connection, 50 + 1024);
Below logs show successful packets, followed by error packets and then
successful packets after reconnect.
Please let me know how to fix the issue.
Thanks and Best regards,
Prakash
Read 21 bytes.
hex:[7e a0 13 41 03 fc fe 88 e6 e7 00 c4 01 c1 00 12 13 7e 03 94 7e ]
Read 23 bytes.
hex:[7e a0 15 41 03 1e 78 07 e6 e7 00 c4 01 c1 00 06 00 00 00 0e 03 f1 7e ]
Read 23 bytes.
hex:[7e a0 05 41 03 30 04 cf e6 e7 00 c4 01 c1 00 05 00 00 00 00 b1 05 7e ]
dlms data send failed. try to resend 1/3
Read 9 bytes.
hex:[7e a0 07 41 03 31 5a 24 7e ]
ReadObject failed Register 1.0.1.7.0.255:2 Not enough memory available.
com_readValue failed: 260
Read 21 bytes.
hex:[7e a0 13 41 03 52 8a c4 e6 e7 00 c4 01 c1 00 12 60 f7 66 57 7e ]
Invalid frame 52. Expected 30.
Read 9 bytes.
hex:[7e a0 07 41 03 51 5c 47 7e ]
ReadObject failed Register 1.0.12.7.0.255:2 Not enough memory available.
Read 21 bytes.
hex:[7e a0 13 41 03 74 be 80 e6 e7 00 c4 01 c1 00 12 61 15 a2 8a 7e ]
Invalid frame 74. Expected 30.
Read 9 bytes.
hex:[7e a0 07 41 03 71 5e 66 7e ]
Read 21 bytes.
hex:[7e a0 13 41 03 96 a2 44 e6 e7 00 c4 01 c1 00 12 61 10 0f dd 7e ]
Invalid frame 96. Expected 30.
Read 9 bytes.
hex:[7e a0 07 41 03 91 50 81 7e ]
Read 32 bytes.
hex:[7e a0 1e 41 03 73 8e 7f 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08
04 00 00 00 01 53 3b 7e ]
reconnecting dlms meter
connecting to meter ...
InitializeConnection
Read 32 bytes.
Read 57 bytes.
hex:[7e a0 37 41 03 30 21 79 e6 e7 00 61 29 a1 09 06 07 60 85 74 05 08 01 01
a2 03 02 01 00 a3 05 a1 03 02 01 00 be 10 04 0e 08 00 06 5f 1f 04 00 00 10 14
02 00 00 07 bc 85 7e ]
connected to meter...
Read 21 bytes.
hex:[7e a0 13 41 03 52 8a c4 e6 e7 00 c4 01 c1 00 12 61 15 a2 8a 7e ]
Read 21 bytes.
hex:[7e a0 13 41 03 74 be 80 e6 e7 00 c4 01 c1 00 12 00 05 ae e6 7e ]
Read 20 bytes.
hex:[7e a0 12 41 03 96 19 58 e6 e7 00 c4 01 c1 00 0f 00 9a 42 7e ]
Read 21 bytes.
3 years 10 months ago
The meter is asking for the next frame. I can't say why, because there are no read requests. This might be a random meter issue. I propose that when this happens you close the connection and read the values again.
Prakash
Thanks for the reply.
We've implemented your suggestion. The problem occurs often. We'll contact the manufacturer for any solution.
Prakash
