  3. Which Object Returns The Displayed Energy On The Smart Meter
Which object returns the displayed energy on the smart meter
By achim , 4 August, 2022
i am using the python example and getting the following
[Trace removed.]
No i have figured how to use python3 main.py -S /dev/ttyUSB0 -t Verbose -r sn -g "1.1.1.8.1.255:2" to get the value now i am not sure which object i should select to get the current meter energy reading displayed
4 years 3 months ago
You have read profile genetic. Profile generic is historical data and you need to read the register. The register shows the current value.
Read association view and try to find Active power. Then you need to read it. Because your meter is using Short Name referencing, I can't know the short name that you need to use.
I'll remove the trace because it doesn't spring any value for this and makes it harder to read.
