  3. Failed To Receive Reply From The Device In Given Time
Failed to receive reply from the device in given time
By nomanimran001 , 17 June, 2022
Hello everyone
Currently i am working on DLMS Smart Meter , here I have Elster Meter and i am trying to connect but it showing me same error every time.
well it was working perfectly fine before one month but i moved on another project and now it showing me "Failed to receive reply from the device in given time" every time.
One more very interesting issue is ,i tried to connect with GURUX software but without USB connection with the meter i mean without any connection with the meter and i click on Connect button on GURUX software and after 3 4 seconds it showing same error "Failed to receive reply from the device in given time".
so with connection or without physical connection with meter i am receiving same error.
Parameter and everything i am using same that i was using before.
Please check and guide me.
Muhammad Nouman
4 years 5 months ago
"Failed to receive a reply from the device in given time" means that client didn't receive any reply from the meter. That also happens if there is no connected meter.
One of your settings is wrong or the Elster meter doesn't support DLMS. Is there a DLMS label on the cover of the meter?
nomanimran001
Yes our meter support DLMS
Yes our meter support DLMS and also you can see in below attached picture.
Thank you
nomanimran001
I am using same meter
I am using same meter settings that i tried before and on that time i was connected and successfully getting all the meter readings.
Please find below attached image.
Then the problem is in settings.
Check this video:
https://youtu.be/BeaWKmyMwuE
I hope it will help you to find the correct settings. Check especially the baudrate. That can be anything.
nomanimran001
is Host Address matters ?
if my host Address not working then it can be an issue ?
It might be the server address, especially if you are using the RS-485 bus. Usually, it's client address or wrong serial port settings.
In reply to I am using same meter by nomanimran001
Check your cable if this is the same meter that you were using before.
nomanimran001
How we can Change default
How we can Change default port ?
nomanimran001
In reply to is Host Address matters ? by nomanimran001
COM3 and connected is COM1
nomanimran001
03:16:57.297 Info Opening
03:16:57.297 Info Serial Port Settings: Port Name: COM1 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Flow Control: None Eop: None
nomanimran001
i think GURUX is connected
i think GURUX is connected with COM1 and in my laptop there is no COM1 as i understand.
Please guide me if i am right.
nomanimran001
Hello Mikko Kurunsaari
finally i solved my errors ,Really Thank you so much for your support.
Thank you
I'm glad this works.
nomanimran001
last time i solved and was getting all values perfectly now i don't know why again i am getting same error.
my settings are still same.
please check if you can guide me
Check your serial port settings and cable. I believe that the reason is one of those.
