  3. DLMS COSEM Object Array Manager (class_id = 123) Support
DLMS COSEM Object Array manager (class_id = 123) support
By Dmitry , 18 April, 2022
Hi, Mikko!
Will be support Array manager (class_id = 123) in DLMS.cpp?
Thanks!
Amit kumar
4 years 7 months ago
Hi, Mikko!
Hi, Mikko!
Here want to Log a particular query regarding setting of RTC for some specified meter Where we need
day of week (DOW) in RTC set Command , GXDLMSDirector sent 0xff in field of DOW (day of week)
so RTC Register in controller can not /should not be written
So can u please add day of week in that field so that any when who need DOW can use it other may ignore it
Cmd Sent by GxDLMSDirector
DOW(dayof week is ff)
7e a0 27 03 61 32 b9 7c e6 e6 00 c1 01 c1 00 08 00 00 01 00 00 ff 02 00 09 0c 07 e6 04 15 ff 00 05 1d ff 01 4a 00 ac 36 7e
Manish
In reply to Hi, Mikko! by Amit kumar
Hi Manish,
Hi Manish,
Please, create a new topic if you have a new question. I'll answer your question after that.
Hi Dmitry,
Hi Dmitry,
None of our clients is not using Array manager at the moment, but it's possible to add. It will take some time because of the new version from Gurux.DLMS.AMI is released soon. It can be done after that.
Do you need it for GXDLMSDirector or ANSI C++?
Dmitry
Thank you very much!
Yes, it need for GXDLMSDirector for debug. And DLMS.cpp library
