  3. Read Out a Simple Obis Code With Python
Read out a simple obis code with Python
By Frank G , 19 January, 2022
Hello Mikko,
I am trying to read out a simple attribute of one object (obiscode) using the python library.
It looks like the meter accept the SNRM and also AARQ. But I am not able to read the attribute
Would you please check this code:
client = GXDLMSClient(forAuthentication=Authentication.NONE)
client.useLogicalNameReferencing = True
client.clientAddress = 0x10
client.serverAddress = 0x4010
port = GXSerial(port="COM6")
port.open()
reader = GXDLMSReader(
client=client,
media=port,
trace=0x8,
invocationCounter=0
reply = GXReplyData()
data = client.snrmRequest
if data:
reader.readDLMSPacket(data, reply)
client.parseUAResponse(reply.data)
for it in client.aarqRequest():
reply.clear()
reader.readDLMSPacket(it, reply)
client.parseAareResponse(reply.data)
serial = GXDLMSData("0.0.96.1.0.255");
serial.read(obj, 2);
The Log in Hex:
ClientAddress: 0x10
ServerAddress: 0x4010
TX: 17:47:49 7E A0 0A 00 02 00 21 21 93 A0 C4 7E
RX: 17:47:49 7E A0 0A 21 00 02 00 21 73 FC D4 7E
TX: 17:47:49 7E A0 2E 00 02 00 21 21 10 C6 7E E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01
BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 17:47:49 7E A0 3A 21 00 02 00 21 30 29 72 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01
A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 00
7D 00 07 6D C3 7E
File "
\Desktop\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\frank.py", line 52, in <module>
AttributeError: 'GXDLMSData' object has no attribute 'read'
Many Thanks
Frank
4 years 10 months ago
Change this:
obj = GXDLMSData("0.0.96.1.0.255");
reader.read(obj, 2);
Frank G
Many Thanks Mikko. it works
Many Thanks Mikko. it works now
Toni
4 years 9 months ago
Please how can I run the
Please how can I run the gurux as a script instead of the command line as seen above? Thanks
In reply to Please how can I run the by Toni
Hi Toni,
Hi Toni,
Please, create a new topic if you have a new question. I'll answer your question then.
