  3. Read Meter Data Using Serial Number Instead of Server Address
Read meter data using serial number instead of server address
By romjer , 14 October, 2021
Good day,
I use Gurux.DLMS.Client.Example.python for reading of Iskraemeco MT372 meters and all works just fine, but we also have some MT174 meters which I think don't have server address parameter and we have to use serial number instead of server address.
Command which I tried to use is below:
python main.py -h 192.168.1.221 -p 4001 -n "71201711" -g "0.0.1.0.0.255:2" -t Verbose
gurux_dlms version: 1.0.110
gurux_net version: 1.0.18
gurux_serial version: 1.0.18
ClientAddress: 0x10
ServerAddress: 0x4a97
Standard: Standard.DLMS
TX: 13:58:39 7E A0 0A 00 02 2A 2F 21 93 46 87 7E
RX: 13:58:54
File "main.py", line 88, in main
reader.initializeConnection()
File "/home/romjer/PycharmProjects/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 306, in initializeConnection
File "/home/romjer/PycharmProjects/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 118, in readDLMSPacket
File "/home/romjer/PycharmProjects/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 168, in readDLMSPacket2
raise e
File "/home/romjer/PycharmProjects/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 161, in readDLMSPacket2
raise TimeoutException("Failed to receive reply from the device in given time.")
gurux_common.TimeoutException.TimeoutException: Failed to receive reply from the device in given time.
Can some body explain whats wrong in my command and is it possible at all to use gurux python client in this manner ?
5 years 1 month ago
Your parameters look good, but in my mind, MT174 is using IEC 62056-21 and not DLMS.
There might be newer versions, so you need to verify this for the meter vendor.
