  3. MT372 GenericProfile Wrong Range Data In Python
MT372 GenericProfile wrong range data in python
By romjer , 7 October, 2021
Good day.
I'm trying to read generic profile of a Iskraemeco MT372 meters using bit modified Gurux.DLMS.Client.Example.python. I can get some data, but the range of the received data does not match defined range in my code. My python code looks like this:
loadProfile = GXDLMSProfileGeneric("1.0.99.1.0.255")
captureObjects = reader.read(loadProfile, 3)
capturePeriod = reader.read(loadProfile, 4)
start = datetime.datetime(year=2021, month=10, day=1, hour=0, minute=0)
end = datetime.datetime.now() # datetime.datetime(2021, 10, 7, 17, 14, 11, 537775)
rows = reader.readRowsByRange(loadProfile, start, end)
In such example rows contain data from 09/24/21 06:00:00 until 09/30/21 23:00:00.
In case of defining of another range the receiving data also changes according to an algorithm that I don't understand.
Can somebody explain what's wrong in my code, why received data range is wrong ?
5 years 1 month ago
Your code looks correct. I did try to read MT372 and it worked like expected. Can you add gex trace from the sent bytes so I can check it?
romjer
5 years 1 month ago
Thank you for prompt replay.
Trace is below.
ClientAddress: 0x10
ServerAddress: 0xa1
Standard: Standard.DLMS
TX: 10:28:18 7E A0 08 02 43 21 93 F0 61 7E
RX: 10:28:18 7E A0 1F 21 02 43 73 B3 A2 81 80 12 05 01 5A 06 01 5A 07 04 00 00 00 01 08 04 00 00 00 01 28 B5 7E
TX: 10:28:18 7E A0 45 02 43 21 10 35 6A E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF A9 FD 7E
RX: 10:28:18 7E A0 39 21 02 43 30 25 89 E6 E7 00 61 2A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 11 04 0F 08 01 00 06 5F 1F 04 00 00 1C 1D 04 00 00 07 20 DB 7E
TX: 10:28:18 7E A0 1A 02 43 21 32 BB 77 E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 03 00 8C 90 7E
RX: 10:28:18 7E A8 64 21 02 43 52 7F E1 E6 E7 00 C4 01 C1 00 01 06 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 60 F0 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 05 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 05 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 AF 5E 7E
TX: 10:28:18 7E A0 08 02 43 21 51 EE 84 7E
RX: 10:28:18 7E A0 25 21 02 43 54 77 6F 02 05 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 05 00 FF 0F 02 12 00 00 D4 C1 7E
TX: 10:28:18 7E A0 1A 02 43 21 74 89 50 E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 04 00 84 DD 7E
RX: 10:28:18 7E A0 16 21 02 43 76 7A A4 E6 E7 00 C4 01 C1 00 06 00 00 0E 10 EC 92 7E
TX: 10:28:18 7E A0 4D 02 43 21 96 2B D1 E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E5 0A 01 05 00 00 00 00 FF 4C 00 09 0C 07 E5 0A 08 05 0A 1C 12 00 FF 4C 00 01 00 B8 16 7E
RX: 10:28:18 7E A8 64 21 02 43 98 29 88 E6 E7 00 C4 02 C1 00 00 00 00 00 00 82 03 F4 01 81 B3 02 06 09 0C 07 E5 09 1E 04 17 00 00 00 FF 88 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 10 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 D5 F4 7E
TX: 10:28:18 7E A0 08 02 43 21 B1 E0 63 7E
RX: 10:28:18 7E A8 64 21 02 43 9A 3B AB 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 8F C6 7E
TX: 10:28:18 7E A0 08 02 43 21 D1 E6 00 7E
RX: 10:28:18 7E A8 64 21 02 43 9C 0D CE 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 CD 70 7E
TX: 10:28:18 7E A0 08 02 43 21 F1 E4 21 7E
RX: 10:28:18 7E A8 64 21 02 43 9E 1F ED 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 D1 5C 7E
TX: 10:28:18 7E A0 08 02 43 21 11 EA C6 7E
RX: 10:28:18 7E A8 64 21 02 43 90 61 04 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 73 C9 7E
TX: 10:28:18 7E A0 08 02 43 21 31 E8 E7 7E
RX: 10:28:19 7E A8 64 21 02 43 92 73 27 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 D1 6D 7E
TX: 10:28:19 7E A0 08 02 43 21 51 EE 84 7E
RX: 10:28:19 7E A8 64 21 02 43 94 45 42 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 31 0A 7E
TX: 10:28:19 7E A0 08 02 43 21 71 EC A5 7E
RX: 10:28:19 7E A8 64 21 02 43 96 57 61 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 71 90 7E
TX: 10:28:19 7E A0 08 02 43 21 91 E2 42 7E
RX: 10:28:19 7E A8 64 21 02 43 98 29 88 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 CF 7E
TX: 10:28:19 7E A0 08 02 43 21 B1 E0 63 7E
RX: 10:28:19 7E A8 64 21 02 43 9A 3B AB 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 5A 6E 7E
TX: 10:28:19 7E A0 08 02 43 21 D1 E6 00 7E
RX: 10:28:19 7E A8 64 21 02 43 9C 0D CE 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 94 49 7E
TX: 10:28:19 7E A0 08 02 43 21 F1 E4 21 7E
RX: 10:28:19 7E A0 2F 21 02 43 9E 89 4A 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 72 20 7E
TX: 10:28:19 7E A0 14 02 43 21 18 5B 98 E6 E6 00 C0 02 C1 00 00 00 00 D8 AF 7E
RX: 10:28:19 7E A8 64 21 02 43 B0 63 25 E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 03 F4 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 C8 1B 7E
TX: 10:28:19 7E A0 08 02 43 21 31 E8 E7 7E
RX: 10:28:19 7E A8 64 21 02 43 B2 71 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 5F F3 7E
RX: 10:28:19 7E A8 64 21 02 43 B4 47 63 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 CE 8A 7E
RX: 10:28:19 7E A8 64 21 02 43 B6 55 40 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 B6 B8 7E
RX: 10:28:19 7E A8 64 21 02 43 B8 2B A9 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 F4 6D 7E
RX: 10:28:19 7E A8 64 21 02 43 BA 39 8A 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 B3 1F 7E
RX: 10:28:19 7E A8 64 21 02 43 BC 0F EF 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 87 0F 7E
RX: 10:28:19 7E A8 64 21 02 43 BE 1D CC 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 C1 16 7E
TX: 10:28:19 7E A0 08 02 43 21 11 EA C6 7E
RX: 10:28:19 7E A8 64 21 02 43 B0 63 25 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 7E 89 7E
RX: 10:28:20 7E A8 64 21 02 43 B2 71 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 F4 6D 7E
TX: 10:28:20 7E A0 08 02 43 21 51 EE 84 7E
RX: 10:28:20 7E A8 64 21 02 43 B4 47 63 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 F0 F7 7E
TX: 10:28:20 7E A0 08 02 43 21 71 EC A5 7E
RX: 10:28:20 7E A0 2F 21 02 43 B6 C3 E7 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 62 EA 7E
TX: 10:28:20 7E A0 14 02 43 21 9A 41 3F E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
RX: 10:28:20 7E A8 64 21 02 43 D8 2D CA E6 E7 00 C4 02 C1 00 00 00 00 02 00 82 03 F4 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 A0 0E 7E
TX: 10:28:20 7E A0 08 02 43 21 B1 E0 63 7E
RX: 10:28:20 7E A8 64 21 02 43 DA 3F E9 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 F5 C8 7E
TX: 10:28:20 7E A0 08 02 43 21 D1 E6 00 7E
RX: 10:28:20 7E A8 64 21 02 43 DC 09 8C 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 8B 71 7E
TX: 10:28:20 7E A0 08 02 43 21 F1 E4 21 7E
RX: 10:28:20 7E A8 64 21 02 43 DE 1B AF 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 F2 3C 7E
TX: 10:28:20 7E A0 08 02 43 21 11 EA C6 7E
RX: 10:28:20 7E A8 64 21 02 43 D0 65 46 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 11 E0 7E
TX: 10:28:20 7E A0 08 02 43 21 31 E8 E7 7E
RX: 10:28:20 7E A8 64 21 02 43 D2 77 65 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 A4 61 7E
RX: 10:28:20 7E A8 64 21 02 43 D4 41 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 9F 2A 7E
RX: 10:28:20 7E A8 64 21 02 43 D6 53 23 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 5F 75 7E
TX: 10:28:20 7E A0 08 02 43 21 91 E2 42 7E
RX: 10:28:20 7E A8 64 21 02 43 D8 2D CA 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 F0 8D 7E
RX: 10:28:20 7E A8 64 21 02 43 DA 3F E9 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 F3 F7 7E
RX: 10:28:21 7E A8 64 21 02 43 DC 09 8C 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 D1 0E 7E
TX: 10:28:21 7E A0 08 02 43 21 F1 E4 21 7E
RX: 10:28:21 7E A0 2F 21 02 43 DE 8D 08 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 6D E1 7E
TX: 10:28:21 7E A0 14 02 43 21 1C 7F DE E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
RX: 10:28:21 7E A8 64 21 02 43 F0 67 67 E6 E7 00 C4 02 C1 00 00 00 00 03 00 82 03 F4 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 64 1C 7E
TX: 10:28:21 7E A0 08 02 43 21 31 E8 E7 7E
RX: 10:28:21 7E A8 64 21 02 43 F2 75 44 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 FE E5 7E
TX: 10:28:21 7E A0 08 02 43 21 51 EE 84 7E
RX: 10:28:21 7E A8 64 21 02 43 F4 43 21 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 33 57 7E
TX: 10:28:21 7E A0 08 02 43 21 71 EC A5 7E
RX: 10:28:21 7E A8 64 21 02 43 F6 51 02 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 45 0D 7E
TX: 10:28:21 7E A0 08 02 43 21 91 E2 42 7E
RX: 10:28:21 7E A8 64 21 02 43 F8 2F EB 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 FF 77 7E
TX: 10:28:21 7E A0 08 02 43 21 B1 E0 63 7E
RX: 10:28:21 7E A8 64 21 02 43 FA 3D C8 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 60 EF 7E
TX: 10:28:21 7E A0 08 02 43 21 D1 E6 00 7E
RX: 10:28:21 7E A8 64 21 02 43 FC 0B AD 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 2E D8 7E
RX: 10:28:21 7E A8 64 21 02 43 FE 19 8E 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 F0 9E 7E
TX: 10:28:21 7E A0 08 02 43 21 11 EA C6 7E
RX: 10:28:21 7E A8 64 21 02 43 F0 67 67 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 45 C8 7E
RX: 10:28:21 7E A8 64 21 02 43 F2 75 44 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 DC E9 7E
RX: 10:28:21 7E A8 64 21 02 43 F4 43 21 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 19 55 7E
RX: 10:28:21 7E A0 2F 21 02 43 F6 C7 A5 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 56 E4 7E
TX: 10:28:21 7E A0 14 02 43 21 9E 65 79 E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E
RX: 10:28:22 7E A8 64 21 02 43 18 21 0C E6 E7 00 C4 02 C1 01 00 00 00 04 00 82 01 BB 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 02 02 06 00 11 00 06 00 2A 02 7E
TX: 10:28:22 7E A0 08 02 43 21 B1 E0 63 7E
RX: 10:28:22 7E A8 64 21 02 43 1A 33 2F 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 74 B5 7E
TX: 10:28:22 7E A0 08 02 43 21 D1 E6 00 7E
RX: 10:28:22 7E A8 64 21 02 43 1C 05 4A 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 AC 94 7E
TX: 10:28:22 7E A0 08 02 43 21 F1 E4 21 7E
RX: 10:28:22 7E A8 64 21 02 43 1E 17 69 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 15 E0 7E
TX: 10:28:22 7E A0 08 02 43 21 11 EA C6 7E
RX: 10:28:22 7E A8 64 21 02 43 10 69 80 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 06 00 11 00 06 00 00 00 0A 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 02 06 00 11 00 06 00 00 00 09 06 00 00 00 00 06 00 2F 76 7E
TX: 10:28:22 7E A0 08 02 43 21 31 E8 E7 7E
RX: 10:28:22 7E A0 12 21 02 43 12 48 AC 00 00 00 06 00 00 00 00 E0 58 7E
5 years 1 month ago
Can you read the sort method (attribute index #5) and add it here? I need only the value.
romjer
5 years 1 month ago
Sure.
Sure.
Index: 5 Value: SortMethod.SMALLEST
5 years 1 month ago
And that is the reason. Meters are usually using FIFO or largest. Your meter is a special case because it doesn't send the date time after the first row. The idea is to save bytes.
We make the change and release a new version soon.
5 years 1 month ago
This is changed. Get the latest version.
http://gurux.fi/node/19202
romjer
5 years 1 month ago
Kitos Mikko,
Kitos Mikko,
now all works correctly.
