  3. DLMS Translator
DLMS Translator
By jrudilla , 6 September, 2021
I have to make a translator of the data already extracted from a meter in python but I am not being able to achieve it, in the translator located on the web I am not able to translate the frame, but in the Gurux DLMS Translator I can, specifically in the Data to XML tab -> Pdu To XML.
This is the code I am using to translate it and the frame.
from gurux_dlms import GXDLMSTranslator
data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
t = GXDLMSTranslator()
t.pduToXml(data)
print(t.pduToXml(data))
Shouldn't you use datatoXml? In that case, what function of the agrees with the options of the Gurux DLMS Director.
Thanks for your help
5 years 2 months ago
I'm sorry. I don't understand what is the problem. You should use dataToXml.
Try this:
bb = GXByteBuffer()
bb.setHexString(data);
print(t.dataToXml(bb))
I tested this with your data and it worked as expected.
jrudilla
Hi, Thank you, works perfect.
