  3. Settings Doesn't Work On .NET Client Whereas Does On GXDirector
Settings doesn't work on .NET client whereas does on GXDirector
By hhkx , 4 August, 2021
I am using same settings on both .net client and gxdlmsdirector. However, .net client can't connect to the meter.
Meter brand is sanxing.
Please see the attachment for the settings and below for .net code:
_dlmsSettings = new DLMS.ProtocolProvider.Settings();
_dlmsSettings.Scaler = 1;
_dlmsSettings.Trace = TraceLevel.Verbose;
_dlmsSettings.Client.Authentication = Authentication.None;
_dlmsSettings.Client.Ciphering.Security = (byte)Security.None;
_dlmsSettings.Iec = false;
_dlmsSettings.Client.UseLogicalNameReferencing = true;
_dlmsSettings.Client.ClientAddress = 10;
_dlmsSettings.Client.InterfaceType = InterfaceType.HDLC;
_dlmsSettings.Client.ServerAddress = 1;
_dlmsSettings.Media = new GXNet() {
HostName =ipAddress,
Port = 502,
Protocol = NetworkType.Tcp,
Server = false,
Trace = TraceLevel.Verbose,
Send SNRM request.7E A0 07 03 15 93 CD D0 7E
Info: Receive-Send Waiting Time: 15 sn.
TX: 10:16:51 7E A0 07 03 15 93 CD D0 7E
TX: 10:17:06 7E A0 07 03 15 93 CD D0 7E
TX: 10:17:21 7E A0 07 03 15 93 CD D0 7E
5 years 3 months ago
Your client address is wrong. It should be 0x10. Your server address is also different. You can count it like this:
_dlmsSettings.Client.ServerAddress = GXDLMSClient.GetServerAddress(0x3000, 1);
Check also your wait time.
hhkx
I tried it again but still not connecting.
_dlmsSettings.Client.ClientAddress = 0x10; // 16;
_dlmsSettings.Client.ServerAddress = GXDLMSClient.GetServerAddress(1, 3000);
// GetServerAddress(int logicalAddress, int physicalAddress); Also tried the other way around.
DLMS v1.4 - Send SNRM request.7E A0 0A 00 02 2E 71 21 93 52 66 7E
DLMS v1.4 - Info: Receive-Send Waiting Time: 15 sn.
DLMS v1.4 - TX: 12:15:21 7E A0 0A 00 02 2E 71 21 93 52 66 7E
DLMS v1.4 - TX: 12:15:36 7E A0 0A 00 02 2E 71 21 93 52 66 7E
DLMS v1.4 - TX: 12:15:51 7E A0 0A 00 02 2E 71 21 93 52 66 7E
hhkx
It worked with GXDLMSClient
It worked with GXDLMSClient.GetServerAddress(1, 12288);
12288 is the number replaced by 3000 when I unchecked hex on GXDLMSDirector.
Hi Aaron,
Hi Aaron,
Thank you for the information. I forget to add 0x. I'll add it now.
