  3. Unable To Parse Profile Generic Rows In Gurux.DLMS.Net But Works Fine In GXDLMSDirector
Unable to parse profile generic rows in Gurux.DLMS.Net but works fine in GXDLMSDirector
By rdk1 , 4 November, 2020
I am reading rows of a profile generic object by range
dlmsClient.ReadRowsByRange(
profileGeneric,
new DateTime(2020, 10, 15, 0, 0, 0),
new DateTime(2020, 10, 16, 0, 0, 0)
And receiving 8 frames in response with 974 bytes of data.
I can see that response contains the real data, but unable to parse it:
dlmsClient.UpdateValue(profileGeneric, 2, replyData.Value);
always gives empty buffer.
Capture objects of the profile:
Gurux.DLMS.Objects.GXDLMSData | 2 | None
Gurux.DLMS.Objects.GXDLMSRegister | 2
[Gurux.DLMS.Objects.GXDLMSRegister | 2
The raw data in response contains the real values, but it not parsed into buffer.
I can successfully read and see the rows with GXDLMSDirector
Meter: Itron ACE6000 (not with the best DLMS support, but GXDLMSDirector somehow manages to read the rows)
Request:
https://rdk.ee/dev/gx/request.txt
Response:
https://rdk.ee/dev/gx/response.txt
Response data:
https://rdk.ee/dev/gx/response-data.txt
rdk1
6 years ago
The data can be translated
The data can be translated into readable xml with GXDLMSTranslator and it seems to be ok.
Still to find out why it is not correctly parsed into the buffer.
rdk1
6 years ago
The problem is solved. There were several data blocks, but I was reading only the first, so the data was not read fully.
6 years ago
I'm glad that this is solved. I'm sorry that I was not able to answer faster, but we have fighted with the new release from GXDLMSDirector and it's finally released.
