  3. Image Transfer Not Working - DLMS C, IGNORE_MALLOC
Image Transfer not working - DLMS C, IGNORE_MALLOC
By Vasanth , 21 September, 2020
Hello Mikko,
We are using Gurux DLMS C library with IGNORE_MALLOC in our Three phase meter. Currently we trying to do Image Transfer using Gurux Director. But meter replied with error ( Device reports read / write failed).
Issue area:
in invoke_ImageTransfer function, imageActivateInfo.size value is 0.
if ((ret = arr_getByIndex(&target->imageActivateInfo, target->imageActivateInfo.size, (void**)&item, sizeof(gxImageActivateInfo))) != 0)
return ret;
Trace Details:
09:29:46 Reading object 0.0.44.0.0.255, interface ImageTransfer
TX: 7E A0 19 03 61 7E 61 16 E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 05 00 73 FC 7E
09:29:47
RX: 7E A0 12 61 03 16 2A DF E6 E7 00 C4 01 C1 00 03 01 B3 FA 7E
09:29:47 Reading object 0.0.44.0.0.255, interface ImageTransfer
TX: 7E A0 19 03 61 90 11 18 E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 02 00 7B B1 7E
09:29:47
RX: 7E A0 15 61 03 38 77 40 E6 E7 00 C4 01 C1 00 06 00 00 00 32 EC 0A 7E
09:29:47 Updating image project...
TX: 7E A0 28 03 61 B2 48 4A E6 E6 00 C3 01 C1 00 12 00 00 2C 00 00 FF 01 01 02 02 09 06 73 64 66 73 64 66 06 00 02 91 9A E1 57 7E
09:29:47
RX: 7E A0 11 61 03 5A 8F 72 E6 E7 00 C7 01 C1 03 00 94 9E 7E
Could you please help us to resolve this issue.
Vasanth
CMS Computers Ltd.
6 years 2 months ago
Image transfer initialize failed for some reason. Make sure that there is enough flash available for the image. Check also your image_identifier. Is that what your meter expects.
Vasanth
Thankyou for your reply.
We have enough free flash memory. 100+ KB free flash still available. We using 256KB Flash micro controller. Around 120KB only still utilized.
In invoke_ImageTransfer function , imageActivateInfo.size value is always 0.
Please check the attached image. Here it returns with error.
Can you please guide as to resolve this issue.
Vasanth
6 years 1 month ago
I'm sorry for the slow reply. Our clients and the new version from Blue Book have kept us busy last weeks.
You need to allocate memory for image activate info. That is causing the problem.
We are releasing a new version from ANSI C in the end of next week where the server example is improved and there is an example of how to do it.
