  3. Read-write Error With Gurux Python Code
Read-write error with Gurux Python code
By PrateekGoyal , 27 August, 2020
I am trying to read data from Landis+Gyr E150 meter using the Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python code.
I am sending the query:
python main.py -S /dev/ttyUSB3
On a lot of lines, I am getting "Device reports Read-Write denied". What is the meaning of this?
[Trace removed to simplify reading.]
6 years 2 months ago
Those attributes are not implemented in the meter. Your meter doesn't support the time zone or DST.
The client example is improved. If the attribute is not readable it's not read. Get the latest version.
I'll remove trace because it's not needed.
PrateekGoyal
How to read the parameters
How to read the parameters like voltage, current, power etc?
If you can't see them you need to change authentication to Low. I believe that best way to start is if you install GXDLMSDirector and try to read your app with it.
PrateekGoyal
Miko, with your updated
Miko, with your updated python code on GitHub, the following problem is coming.
Error! Index: 7 can only concatenate str (not "int") to str
File "/home/prateek/Documents/DLMS/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 429, in getReadOut
self.writeTrace("Attribute" + pos + " is not readable.", TraceLevel.INFO)
TypeError: can only concatenate str (not "int") to str
And when I set the authentication to Low and give the password, with the query:
python main.py -S /dev/ttyUSB3 -a Low -P 11111111
This is the error: "Access Error : Device reports a hardware fault."
I'm sorry about this. This is now updated. Get the latest version.
PrateekGoyal
The code is working fine now,
Thanks, the code is working fine now, but how to read individual parameters with code. Because I am using Linux, and GXDLMSDirector runs on Windows.
You need to know what you want to read. You can read ex. the clock like this:
obj = GXDLMSClock("0.0.1.0.0.255")
val = self.read(obj, 2)
self.showValue(2, val)
The current example walks through all the objects and reads them all.
PrateekGoyal
Where shall I put this code
Where shall I put this code and what script to run?
You need to modify the source code. I believe that the best way to go is if you add -g parameter. It'll read the wanted object from the meter.
Example:
-g 0.0.1.0.0.255:2
This reads the current time from the meter.
PrateekGoyal
Yes, I was doing this only.
Yes, I was doing this only. But when I added some code with -g or -v, there was an error.
It might be that you can't access all the objects if you read your meter without authentication. Have you tried to connect using authentication? You can add -o parameter and save values to the XML file. You can then check if the object exists.
PrateekGoyal
Hi Mikko, I am getting this
Hi Mikko, I am getting this as xml response:
<?xml version="1.0" ?>
<Objects>
<GXDLMSAssociationLogicalName>
<LN>0.0.40.0.0.255</LN>
<Description>Ch. 0 Current association</Description>
<ClientSAP>16</ClientSAP>
<ServerSAP>1</ServerSAP>
<ApplicationContextName>
<JointIsoCtt>0</JointIsoCtt>
<Country>0</Country>
<CountryName>0</CountryName>
<IdentifiedOrganization>5</IdentifiedOrganization>
<DlmsUA>8</DlmsUA>
<ApplicationContext>1</ApplicationContext>
<ContextId>1</ContextId>
</ApplicationContextName>
<XDLMSContextInfo>
<Conformance>524288</Conformance>
<MaxReceivePduSize>100</MaxReceivePduSize>
<MaxSendPduSize>100</MaxSendPduSize>
<DlmsVersionNumber>6</DlmsVersionNumber>
<QualityOfService>0</QualityOfService>
<CypheringInfo/>
</XDLMSContextInfo>
<AuthenticationMechanismName>
<DlmsUA>8</DlmsUA>
<AuthenticationMechanismName>2</AuthenticationMechanismName>
<MechanismId>0</MechanismId>
<Secret/>
<AssociationStatus>2</AssociationStatus>
<SecuritySetupReference/>
</GXDLMSAssociationLogicalName>
<LN>0.0.40.0.1.255</LN>
<Description>Ch. 0 Association #1</Description>
<DlmsUA>8</DlmsUA>
<XDLMSContextInfo>
<CypheringInfo/>
</XDLMSContextInfo>
<DlmsUA>8</DlmsUA>
<Secret/>
<GXDLMSData>
<LN>0.0.42.0.0.255</LN>
<Description>Ch. 0 COSEM Logical device name</Description>
<Value Type="9" UIType="10">LGZ-LGC110/E150</Value>
</GXDLMSData>
<GXDLMSClock>
<LN>0.0.1.0.0.255</LN>
<Description>Ch. 0 Clock object #1</Description>
<Time>09/01/2020 10:20:50</Time>
<TimeZone>0</TimeZone>
<Status>0</Status>
<Begin/>
<End/>
<Deviation>0</Deviation>
<Enabled>0</Enabled>
<ClockBase>0</ClockBase>
</GXDLMSClock>
<GXDLMSData>
<LN>0.0.96.1.0.255</LN>
<Description>Ch. 0 Device ID 1, manufacturing number</Description>
<Value Type="10">26755917 </Value>
</GXDLMSData>
</Objects>
Can it be that I can't read voltage, current etc because I am not providing any client or server address?
As I told in the previous topic, you try to connect without authentication. You need to change the authentication level and client address. I believe it will help you and you can see more objects.
PrateekGoyal
With authentication, both
With authentication, both High and Low, I am getting this error: python main.py -S /dev/ttyUSB2 -a Low -P 11111111
gurux_dlms version: 1.0.93
gurux_net version: 1.0.17
gurux_serial version: 1.0.15
ClientAddress: 0x10
Standard: Standard.DLMS
Is it possible to get the client or server address, because the manufacturer is not willing to give.
Sounds interesting if you have bought the meter and the manufacturer is now willing to give the address.
We have two options.
1. If you have a manufacturer's application and you can get the trace I can get the address info from there.
2. If you are sure from the password you can try with different client addresses. Add parameter -c and start address from 1. This will take some time, but client address is usually quite small.
Indian standard is using values 32, 48, 64, and 80.
PrateekGoyal
1. Is only address enough and
1. Is only address enough and how can you help me in getting the trace?
2. Is there any method to check whether the password is correct or not?
You need a sniffer to get a trace. If you are using TCP/IP connection you can use Wireshark. If you are using the serial port you need serial port monitor application.
If the password is wrong meter returns an error.
PrateekGoyal
This was the trace I got when
This was the trace I got when I pinged the instantaneous parameter values from the L&G official software:
[01/09/2020 12:33:42] Read data (COM19)
7e a0 0a 41 00 02 04 01 1f 75 ba 7e ~ .A.....uº~
[01/09/2020 12:33:51] Read data (COM19)
7e a0 23 41 00 02 04 01 73 a5 31 81 80 14 05 02 ~ #A....s¥1€...
00 7e 06 02 00 7e 07 04 00 00 00 01 08 04 00 00 .~...~..........
00 01 3e 8d 7e ..>~
7e a0 3a 41 00 02 04 01 30 ca b5 e6 e7 00 61 29 ~ :A....0ʵæç.a)
a1 09 06 07 60 85 74 05 08 01 01 a2 03 02 01 00 ¡...`…t....¢....
a3 05 a1 03 02 01 00 be 10 04 0e 08 00 06 5f 1f £.¡....¾......_.
04 00 00 10 14 00 64 00 07 e6 da 7e ......d..æÚ~
[01/09/2020 12:33:52] Read data (COM19)
7e a0 25 41 00 02 04 01 52 e3 59 e6 e7 00 c4 01 ~ %A....RãYæç.Ä.
81 00 0a 10 32 36 37 35 35 39 31 37 20 20 20 20 ...26755917
20 20 20 20 5d 97 7e ]—~
7e a0 21 41 00 02 04 01 74 a1 72 e6 e7 00 c4 01 ~ !A....t¡ræç.Ä.
81 00 09 0c 07 e4 09 01 02 0c 22 09 ff 80 00 00 ....ä....".ÿ€..
36 d0 7e 6Ð~
7e a0 29 41 00 02 04 01 96 51 68 e6 e7 00 c4 01 ~ )A....–Qhæç.Ä.
81 00 09 14 2a 36 38 2e 35 30 32 34 30 30 31 30 ...*68.50240010
30 36 30 43 46 32 72 42 41 16 7e 060CF2rBA.~
7e a0 1f 41 00 02 04 01 b8 aa 2e e6 e7 00 c4 01 ~ .A....¸ª.æç.Ä.
81 00 0a 0a 4c 61 6e 64 69 73 2b 47 79 72 f1 6f ...Landis+Gyrño
7e ~
[01/09/2020 12:33:53] Read data (COM19)
7e a0 25 41 00 02 04 01 da a3 51 e6 e7 00 c4 01 ~ %A....Ú£Qæç.Ä.
7e a0 1f 41 00 02 04 01 fc 8a 2a e6 e7 00 c4 01 ~ .A....üŠ*æç.Ä.
7e ~
7e a0 18 41 00 02 04 01 1e 8e 29 e6 e7 00 c4 01 ~ .A.....Ž)æç.Ä.
81 00 0a 03 30 30 31 80 9d 7e ...001€~
[01/09/2020 12:33:54] Read data (COM19)
7e a0 16 41 00 02 04 01 30 d3 67 e6 e7 00 c4 01 ~ .A....0Ógæç.Ä.
81 00 0a 01 35 80 4c 7e 7e a0 14 41 00 02 04 01 ...5€L~~ .A....
52 7c 10 e6 e7 00 c4 01 81 01 03 05 84 7e R|.æç.Ä....„~
7e a0 17 41 00 02 04 01 74 26 fc e6 e7 00 c4 01 ~ .A....t&üæç.Ä.
81 00 0a 02 43 33 54 3c 7e ...C3T<~
7e a0 16 41 00 02 04 01 96 ef a7 e6 e7 00 c4 01 ~ .A....–ï§æç.Ä.
81 00 12 07 e3 bc e8 7e 7e a0 14 41 00 02 04 01 ...ã¼è~~ .A....
b8 28 58 e6 e7 00 c4 01 81 01 03 05 84 7e ¸(Xæç.Ä....„~
[01/09/2020 12:33:55] Read data (COM19)
7e a0 29 41 00 02 04 01 da 39 e0 e6 e7 00 c4 01 ~ )A....Ú9àæç.Ä.
7e a0 1c 41 00 02 04 01 fc e4 82 e6 e7 00 c4 01 ~ .A....ü䂿ç.Ä.
81 00 0a 07 31 30 2d 36 30 20 41 b5 1c 7e 7e a0 ...10-60 Aµ.~~
14 41 00 02 04 01 1e 14 98 e6 e7 00 c4 01 81 01 .A......˜æç.Ä..
03 05 84 7e 7e a0 14 41 00 02 04 01 30 68 50 e6 ..„~~ .A....0hPæ
e7 00 c4 01 81 01 03 05 84 7e ç.Ä....„~
[01/09/2020 12:33:56] Read data (COM19)
7e a0 24 41 00 02 04 01 52 36 c6 e6 e7 00 c4 01 ~ $A....R6Ææç.Ä.
81 00 09 0f 01 01 01 01 01 01 01 01 01 01 01 00 ...............
00 00 00 67 37 7e 7e a0 14 41 00 02 04 01 74 48 ...g7~~ .A....tH
54 e6 e7 00 c4 01 81 01 03 05 84 7e Tæç.Ä....„~
[01/09/2020 12:33:57] Read data (COM19)
7e a0 75 41 00 02 04 01 96 04 ab e6 e7 00 c4 02 ~ uA....–.«æç.Ä.
81 00 00 00 00 01 00 5c 01 07 02 04 12 00 01 09 ......\........
06 00 00 60 01 00 ff 0f 02 12 00 00 02 04 12 00 ...`..ÿ.........
01 09 06 00 00 60 01 01 ff 0f 02 12 00 00 02 04 .....`..ÿ.......
12 00 01 09 06 01 00 00 02 00 ff 0f 02 12 00 00 ..........ÿ.....
02 04 12 00 01 09 06 00 00 5e 5b 09 ff 0f 02 12 .........^[.ÿ...
00 00 02 04 12 00 01 09 06 00 00 5e 5b 0b ff 0f ...........^[.ÿ.
02 12 00 00 fa a3 7e ....ú£~
7e a0 3d 41 00 02 04 01 b8 92 7a e6 e7 00 c4 02 ~ =A....¸’zæç.Ä.
81 01 00 00 00 02 00 24 02 04 12 00 01 09 06 00 ......$........
00 5e 5b 0c ff 0f 02 12 00 00 02 04 12 00 01 09 .^[.ÿ...........
06 00 00 60 01 04 ff 0f 02 12 00 00 20 ed 7e ...`..ÿ..... í~
7e a0 4d 41 00 02 04 01 da ca 2b e6 e7 00 c4 01 ~ MA....ÚÊ+æç.Ä.
81 00 01 01 02 07 0a 10 32 36 37 35 35 39 31 37 .......26755917
20 20 20 20 20 20 20 20 0a 0a 4c 61 6e 64 69 73 ..Landis
2b 47 79 72 0a 03 30 30 31 0a 01 35 0a 02 43 33 +Gyr..001..5..C3
0a 07 31 30 2d 36 30 20 41 12 07 e3 3f 1a 7e ..10-60 A..ã?.~
[01/09/2020 12:33:58] Read data (COM19)
7e a0 75 41 00 02 04 01 fc 58 67 e6 e7 00 c4 02 ~ uA....üXgæç.Ä.
81 00 00 00 00 01 00 5c 01 18 02 04 12 00 08 09 ......\........
06 00 00 01 00 00 ff 0f 02 12 00 00 02 04 12 00 ......ÿ.........
03 09 06 01 00 0c 07 00 ff 0f 02 12 00 00 02 04 ........ÿ.......
12 00 03 09 06 01 00 0b 07 00 ff 0f 02 12 00 00 ..........ÿ.....
02 04 12 00 03 09 06 01 00 5b 07 00 ff 0f 02 12 .........[..ÿ...
00 00 02 04 12 00 03 09 06 01 00 0d 07 00 ff 0f ..............ÿ.
02 12 00 00 5c c7 7e ....\Ç~
7e a0 73 41 00 02 04 01 1e 89 fb e6 e7 00 c4 02 ~ sA.....‰ûæç.Ä.
81 00 00 00 00 02 00 5a 02 04 12 00 03 09 06 01 ......Z........
00 0e 07 00 ff 0f 02 12 00 00 02 04 12 00 03 09 ....ÿ...........
06 01 00 09 07 00 ff 0f 02 12 00 00 02 04 12 00 ......ÿ.........
03 09 06 01 00 01 07 00 ff 0f 02 12 00 00 02 04 ........ÿ.......
12 00 03 09 06 01 00 01 08 00 ff 0f 02 12 00 00 ..........ÿ.....
02 04 12 00 03 09 06 01 00 09 08 00 ff 0f 02 12 ............ÿ...
00 00 90 35 7e ..5~
[01/09/2020 12:33:59] Read data (COM19)
7e a0 73 41 00 02 04 01 30 f5 33 e6 e7 00 c4 02 ~ sA....0õ3æç.Ä.
81 00 00 00 00 03 00 5a 02 04 12 00 04 09 06 01 ......Z........
00 01 06 00 ff 0f 02 12 00 00 02 04 12 00 04 09 ....ÿ...........
06 01 00 01 06 00 ff 0f 05 12 00 00 02 04 12 00 ......ÿ.........
04 09 06 01 00 09 06 00 ff 0f 02 12 00 00 02 04 ........ÿ.......
12 00 04 09 06 01 00 09 06 00 ff 0f 05 12 00 00 ..........ÿ.....
02 04 12 00 03 09 06 00 00 5e 5b 0e ff 0f 02 12 .........^[.ÿ...
00 00 0b e4 7e ...ä~
7e a0 73 41 00 02 04 01 52 e1 73 e6 e7 00 c4 02 ~ sA....Rásæç.Ä.
81 00 00 00 00 04 00 5a 02 04 12 00 01 09 06 00 ......Z........
00 5e 5b 00 ff 0f 02 12 00 00 02 04 12 00 01 09 .^[.ÿ...........
06 00 00 00 01 00 ff 0f 02 12 00 00 02 04 12 00 ......ÿ.........
01 09 06 00 00 60 02 00 ff 0f 02 12 00 00 02 04 .....`..ÿ.......
12 00 03 09 06 01 00 03 07 00 ff 0f 02 12 00 00 ..........ÿ.....
02 04 12 00 03 09 06 01 00 05 08 00 ff 0f 02 12 ............ÿ...
00 00 b1 78 7e ..±x~
[01/09/2020 12:34:00] Read data (COM19)
7e a0 61 41 00 02 04 01 74 a7 b5 e6 e7 00 c4 02 ~ aA....t§µæç.Ä.
81 01 00 00 00 05 00 48 02 04 12 00 03 09 06 00 ......H........
00 60 01 dd ff 0f 02 12 00 00 02 04 12 00 01 09 .`.Ýÿ...........
06 00 00 60 02 c4 ff 0f 02 12 00 00 02 04 12 00 ...`.Äÿ.........
03 09 06 00 00 60 09 80 ff 0f 02 12 00 00 02 04 .....`.€ÿ.......
12 00 03 09 06 00 00 5e 5b 08 ff 0f 02 12 00 00 .......^[.ÿ.....
ee 41 7e îA~
7e a0 74 41 00 02 04 01 96 d1 34 e6 e7 00 c4 02 ~ tA....–Ñ4æç.Ä.
81 00 00 00 00 01 00 5b 01 01 02 18 09 0c 07 e4 ......[.......ä
09 01 02 0c 22 11 ff 80 00 00 12 57 82 06 00 00 ....".ÿ€...W‚...
00 00 06 00 00 00 00 10 00 00 12 01 f4 06 00 00 ............ô...
00 00 05 00 00 00 00 06 00 00 0d d1 06 00 00 0d ...........Ñ....
d1 12 00 00 09 0c 00 00 00 00 ff 00 00 ff ff 80 Ñ.........ÿ..ÿÿ€
00 00 12 00 00 09 0c 00 00 00 00 ff 00 00 ff ff ...........ÿ..ÿÿ
80 00 00 2d 77 7e €..-w~
7e a0 58 41 00 02 04 01 b8 b4 2e e6 e7 00 c4 02 ~ XA....¸´.æç.Ä.
81 01 00 00 00 02 00 3f 06 00 02 ac 24 06 00 00 ......?...¬$...
00 02 06 00 00 00 0c 12 00 00 05 00 00 00 00 06 ................
00 00 00 00 06 00 00 00 00 0a 14 34 34 30 32 31 ...........44021
30 39 33 34 39 32 31 32 34 36 34 36 36 33 34 10 093492124646634.
01 61 06 00 05 09 ff 3b 96 7e .a....ÿ;–~
[01/09/2020 12:34:01] Read data (COM19)
7e a0 75 41 00 02 04 01 da 6c 23 e6 e7 00 c4 02 ~ uA....Úl#æç.Ä.
81 00 00 00 00 01 00 5c 01 11 02 04 12 00 03 09 ......\........
06 01 00 0c 07 00 ff 0f 03 12 00 00 02 04 12 00 ......ÿ.........
03 09 06 01 00 0b 07 00 ff 0f 03 12 00 00 02 04 ........ÿ.......
12 00 03 09 06 01 00 5b 07 00 ff 0f 03 12 00 00 .......[..ÿ.....
02 04 12 00 03 09 06 01 00 0d 07 00 ff 0f 03 12 ............ÿ...
00 00 02 04 12 00 03 09 06 01 00 0e 07 00 ff 0f ..............ÿ.
03 12 00 00 d0 e4 7e ....Ðä~
7e a0 73 41 00 02 04 01 fc 95 3f e6 e7 00 c4 02 ~ sA....ü•?æç.Ä.
00 09 07 00 ff 0f 03 12 00 00 02 04 12 00 03 09 ....ÿ...........
06 01 00 01 07 00 ff 0f 03 12 00 00 02 04 12 00 ......ÿ.........
03 09 06 01 00 01 08 00 ff 0f 03 12 00 00 02 04 ........ÿ.......
12 00 03 09 06 01 00 09 08 00 ff 0f 03 12 00 00 ..........ÿ.....
02 04 12 00 04 09 06 01 00 01 06 00 ff 0f 03 12 ............ÿ...
00 00 a3 ab 7e ..£«~
[01/09/2020 12:34:02] Read data (COM19)
00 09 06 00 ff 0f 03 12 00 00 02 04 12 00 03 09 ....ÿ...........
06 00 00 5e 5b 0e ff 0f 03 12 00 00 02 04 12 00 ...^[.ÿ.........
03 09 06 01 00 03 07 00 ff 0f 02 12 00 00 02 04 ........ÿ.......
12 00 03 09 06 01 00 05 08 00 ff 0f 03 12 00 00 ..........ÿ.....
02 04 12 00 03 09 06 00 00 60 01 dd ff 0f 03 12 .........`.Ýÿ...
00 00 f2 0b 7e 7e a0 3d 41 00 02 04 01 30 d2 72 ..ò.~~ =A....0Òr
e6 e7 00 c4 02 81 01 00 00 00 04 00 24 02 04 12 æç.Ä.......$...
00 03 09 06 00 00 60 09 80 ff 0f 03 12 00 00 02 ......`.€ÿ......
04 12 00 03 09 06 00 00 5e 5b 08 ff 0f 03 12 00 ........^[.ÿ....
00 5e 0a 7e .^.~
7e a0 7d 41 00 02 04 01 52 c0 f5 e6 e7 00 c4 02 ~ }A....RÀõæç.Ä.
81 00 00 00 00 01 00 64 01 01 02 11 02 02 0f fe ......d.......þ
16 23 02 02 0f fd 16 21 02 02 0f fd 16 21 02 02 .#...ý.!...ý.!..
0f fe 16 ff 02 02 0f ff 16 2c 02 02 0f fe 16 1c .þ.ÿ...ÿ.,...þ..
02 02 0f fe 16 1b 02 02 0f 01 16 1e 02 02 0f 01 ...þ............
16 1f 02 02 0f 01 16 1b 02 02 0f 01 16 1c 02 02 ................
0f 00 16 06 02 02 0f fe 16 1d 02 02 0f 01 16 20 .......þ.......
02 02 0f 01 16 1e 02 02 0f ff 16 09 28 d6 7e 7e .........ÿ..(Ö~~
a0 1f 41 00 02 04 01 74 ca 22 e6 e7 00 c4 02 81  .A....tÊ"æç.Ä.
01 00 00 00 02 00 06 02 02 0f 00 16 06 8d 82 7e .............‚~
7e a0 0a 41 00 02 04 01 73 1f 13 7e ~ .A....s..~
Try with parameters -c 32 -s 16640
PrateekGoyal
Command - python main.py -S
Command - python main.py -S COM20 -c 32 -s 16640
Response -
ClientAddress: 0x20
ServerAddress: 0x4100
Can you add -t Verbose
Can you add -t Verbose parameter and add the trace?
PrateekGoyal
python main.py -S COM17 -c 32
python main.py -S COM17 -c 32 -s 16640 -t Verbose
ClientAddress: 0x20
TX: 11:34:52 7E A0 0A 00 02 04 01 41 93 22 D0 7E
RX: 11:35:07
Your data is correct. Check baud-rate. Because the meter is not reply anything it might be wrong.
PrateekGoyal
It is 9600, checked with the
It is 9600, checked with the manufacturer.
With another application, you are using serial port COM19 and with python COM17. Is this correct?
Can you read the meter with GXDLMSDirector?
PrateekGoyal
It is just I have connected a
It is just I have connected a USB hub, and sometimes I connect to it's random port so COM is not a problem. Let me try with GXDLMSDirector.
mekam srilatha
3 years 8 months ago
In reply to With authentication, both by PrateekGoyal
Sir can I know the…
Sir can I know the authentication password for landis gyr E150
