  3. Unable To Communicate With MQTT
Unable to communicate with MQTT
By icabrera , 27 August, 2020
Gurux.MQTT
I am working in a implementation of MQTT for a Smart Meter through LTE. I am not using the Gurux.bridge because my meter supports natively MQTT.
The meter is suscribed to a topic "meter", and also Gurux DLMS director is configured to use the same broker and topic.
When I click on connect in Gurux DLMS director, I received in the another side the following frames:
{"id":1,"sender":"72346f17-90e1-4a7e-aeb7-2104a0891c6e"}
{"id":2,"sender":"72346f17-90e1-4a7e-aeb7-2104a0891c6e","type":3}
Afterthat, Gurux DLMS director says: Invalid topic 'meter'.
In the received data I cannot see payload or data related field, so I am unable to process into the meter and generate an answer.
Any help will be appreciated.
Thanks.
6 years 2 months ago
There are differences because MQTT is not defined on the DLMS standard. Can you share what meter returns and we can check ho to handle this case.ยจ
  • BTN KC BIAK call/wa 0813-627-9539.
  • Bank BTN KC Jakarta Pluit call/wa 0813-627-9539.
  • Bank BTN KC Kemayoran call/wa 0813-627-9539.
  • Bank BTN KK Cempaka Putih Permai call/wa 0813-627-9539.
  • BTN KC Jakarta Pusat call/wa 0813-627-9539.
  • polo
  • Ardiansyah5050
  • berkah
  • bmksdm
  • berkah2026
