  3. Static IP Meter Reading
Static IP meter reading
By epdcldlms , 24 August, 2020
Sir, I am new to this smart meter project can u help me how to establish the connection with the meter using static IP. My meter make is Genus. Shall i need to configure anything in the meter or just inserting the SIM into the meter is sufficient please help me i struck at this point.
6 years 2 months ago
If you are using static IP address you can access your meter with GXDLMSDirector.
Just set correct IP address and try to connect.
epdcldlms
Thank you for quick reply
Thank you for quick reply Mikko Kurunsaari,
is it possible to read that meter (static Ip) using gurx.dlm.client example code in java
Yes, it is. If you are using the static IP address it will behave as using normal TCP/IP connection.
epdcldlms
Thank you sir,
Thank you sir,
-h 117.231.127.7 -p 4059 -c 16 -s 1 -w
i gave these parameters ,while i'm running
i got this error
Authentication: None
ClientAddress: 0x10
java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at gurux.net.GXNet.open(GXNet.java:522)
at gurux.dlms.client.sampleclient.main(sampleclient.java:101)
Your TCP/IP connection fails. Check your IP address and port number.
Try can try to ping your meter.
epdcldlms
Tq sir,
Tq sir,
is there any default port number or where can i find the port number of meter
It depends on the meter. You need to ask this info from the meter vendor.
epdcldlms
Sir, i have contacted the
Sir, i have contacted the vendor and he has given that default port for pull is 4059, i have configured this in the GLXDirector but unable to connect I have given the screen shot plz check whether configuration given is correct or not.
Check that you can access your APN. Also, check the firewall. This error is coming from Windows and it means that connection can't be established. There is nothing that we can do for this.
Verify that your meter is really using static and not dynamic IP addresses.
epdcldlms
Hi sir,
Hi sir,
while running i got this error,please once check this.
java -jar smartMeter.jar -h 10.3.119.104 -p 4059 -c 16 -s 1 -w
java.net.BindException: Permission denied (Bind failed)
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:376)
at java.net.ServerSocket.bind(ServerSocket.java:390)
at java.net.ServerSocket.<init>(ServerSocket.java:252)
at java.net.ServerSocket.<init>(ServerSocket.java:143)
at gurux.net.GXNet.open(GXNet.java:505)
at gurux.dlms.client.sampleclient.main(sampleclient.java:76)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:607)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:61)
Permission denied is OS error. This app is not connecting to the meter. Check that you have a static IP.
Another app expects that meter makes the connection.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
