  3. Inhemeter Connection Settings
By IzakT , 18 April, 2020
Hi there !
Can you assist with DLMS connection settings for inhemeter. I have the model DDZ1513(MBS6K2A-CIP) single phase meter and it's labelled as DLMS compliant but I have tried to connect using the following configs using Python:
ClientAddress: 0x10
RX: 12:20:19
ClientAddress: 0x10
ServerAddress: 0x662b
RX: 12:36:21
6 years 7 months ago
Are you using a serial port or optical probe (head)? If you are using serial port, check your cables.
IzakT
Hi Mikko.
Hi Mikko.
Yes I'm using an optical probe via USB serial port.
My cable is working because I can connect & read my Landis & Gyr E460 meter using the connection settings you provided but Inhemeter isn't responding.
I'm still learning the DLMS protocol and wanted to test & solidify my knowledge through interfacing with meters from different manufacturers.
Hi Isaac,
Hi Isaac,
We don't have DDZ1513 so I can't test this. I belive that your meter don't allow public read.
I can get correct parameters to you if you can read your meter with manufacturer application and you can send a trace here. The first message is enough.
IzakT
I have connected to the meter
I have connected to the meter using the Inhemeter Smart Tools app.
I have attached the trace shown when I 'fired' the connect meter command
I'm sorry to say, but this is not DLMS protocol message. This is a proprietary protocol that they are using in own app.
Can you download GXDLMSDirector and select "IEC" as start protocol? or run your Python command line app with -i parameter.
IzakT
Okay thank you.
Okay thank you.
I have tried using the -i flag that you suggested and it's returning the same as what I posted above.
gurux_dlms version: 1.0.68
gurux_net version: 1.0.17
gurux_serial version: 1.0.14
ClientAddress: 0x10
Standard: Standard.DLMS
File "main.py", line 98, in main
File "/home/izak/Projects/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 504, in readAll
self.initializeConnection()
File "/home/izak/Projects/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 304, in initializeConnection
self.initializeOpticalHead()
File "/home/izak/Projects/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 201, in initializeOpticalHead
raise Exception("Failed to received reply from the media.")
Exception: Failed to received reply from the media.
What is DDZ1513 firmware version? Can you ask is DLMS supported when optical probe is used from the meter vendor?
IzakT
Hi Mikko.
Hi Mikko.
Here's the information I could pull from the device.
Software Version : SKI1-6B-18081001
Protocol Version : V2.07
Logic Device Name : 037205888771
I haven't yet received a response from the manufacturer yet pertaining to whether DLMS is supported over optical probe or not.
Regards
6 years 6 months ago
The optical port is not tested in the latest certificate that I found. I don't know if that is supported. You need to ask this from the meter manufacturer.
https://www.dlms.com/DataExchange/certificate/pdf/Cert_2111_HM_DDZ1513_…
IzakT
Hi Mikko.
Hi Mikko.
Thank you so much. Let me look for a GPRS modem and Sim card for this meter and I will report back when I'm successfully connected.
In the meantime I'll be working with Landis & Gyr E460S which is responding quite well to the GuruX Python library.
Regards.
IzakT
I haven't received any
I haven't received any response from the manufacturer as yet on how I can connect to the meter using DLMS but I have connected the meter to a GPRS modem and the meter is also communicating with the manufacturer's AMI.
I have captured some of the communication logs and they are below, I hope you can help me make sense of this.
2020-05-08 14:26:29 --> Load library DLMSMETER.dll(V2.0.18.191018)
2020-05-08 14:26:29 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1;DEVICE:037205888771;WORKDIR:C:\SmartAMI\Bin\ Ret:6
2020-05-08 14:26:29 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:26:29 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:3
Param[0]:DataType:1;length:12;Datadots:0;reversed:0;format:;verify:0;datalength:11;datacontent:NORMALWRITE
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:19;datacontent:1.0.96.80.1.255;1;2
Param[2]:DataType:10;length:20;Datadots:0;reversed:0;format:;verify:0;datalength:20;datacontent:25998527416274629650
2020-05-08 14:26:29 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:64 Packet:00010012000100386036A1090607608574050801018A0207808B0760857405080201AC0A80083132333435363738BE10040E01000000065F1F0400FFFFFF0200
2020-05-08 14:26:32 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:0;reversed:0;format:;verify:0;datalength:0
PacketLen:51 Packet:000100010012002B6129A109060760857405080101A203020100A305A103020100BE10040E0800065F1F0400001A1D02000007
2020-05-08 14:26:32 --> - 037205888771 - AnalysizePacket End:28436048 Ret:1
PacketLen:43 Packet:0001001200010023C101C200010100605001FF02000A143235393938353237343136323734363239363530
2020-05-08 14:26:33 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:12 Packet:0001000100120004C501C20C
2020-05-08 14:26:33 --> - 037205888771 - AnalysizePacket End:28436048 Ret:-6212
2020-05-08 14:26:42 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:26:42 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
Param[0]:DataType:1;length:12;Datadots:0;reversed:0;format:;verify:0;datalength:10;datacontent:NORMALREAD
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:19;datacontent:1.0.96.50.1.255;3;2
2020-05-08 14:26:42 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001C300030100603201FF0200
2020-05-08 14:26:45 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:2;reversed:0;format:;verify:0;datalength:0
PacketLen:17 Packet:0001000100120009C401C3000500000000
2020-05-08 14:26:45 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:2;reversed:0;format:;verify:0;datalength:4;datacontent:0.00
2020-05-08 14:27:07 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:27:07 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:18;datacontent:1.0.32.7.0.255;3;2
2020-05-08 14:27:07 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001C400030100200700FF0200
2020-05-08 14:27:10 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:15 Packet:0001000100120007C401C400125B36
2020-05-08 14:27:10 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:2;reversed:0;format:;verify:0;datalength:6;datacontent:233.50
2020-05-08 14:27:35 --> - 037213627013 - PtlUninitialize:28435488
2020-05-08 14:28:03 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:28:03 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:3
Param[2]:DataType:10;length:20;Datadots:0;reversed:0;format:;verify:0;datalength:20;datacontent:47584837420734960928
2020-05-08 14:28:03 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:43 Packet:0001001200010023C101C500010100605001FF02000A143437353834383337343230373334393630393238
2020-05-08 14:28:06 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:12 Packet:0001000100120004C501C500
2020-05-08 14:28:06 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:0;reversed:0;format:;verify:0;datalength:16;datacontent:Meter confirmed.
2020-05-08 14:28:06 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:28:06 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:3
Param[2]:DataType:10;length:20;Datadots:0;reversed:0;format:;verify:0;datalength:20;datacontent:13336147649898651096
2020-05-08 14:28:06 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:43 Packet:0001001200010023C101C600010100605001FF02000A143133333336313437363439383938363531303936
2020-05-08 14:28:08 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:12 Packet:0001000100120004C501C600
2020-05-08 14:28:08 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:28:38 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:28:57 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:28:57 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
2020-05-08 14:28:57 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001C700030100603201FF0200
2020-05-08 14:28:59 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:17 Packet:0001000100120009C401C7000500000000
2020-05-08 14:28:59 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:29:33 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:29:33 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:3
2020-05-08 14:29:33 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:43 Packet:0001001200010023C101C800010100605001FF02000A143235393938353237343136323734363239363530
2020-05-08 14:29:36 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:12 Packet:0001000100120004C501C800
2020-05-08 14:29:36 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:29:39 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:29:39 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
2020-05-08 14:29:39 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001C900030100603201FF0200
2020-05-08 14:29:41 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:17 Packet:0001000100120009C401C9000500001388
2020-05-08 14:29:41 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:2;reversed:0;format:;verify:0;datalength:5;datacontent:50.00
2020-05-08 14:34:04 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:34:04 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:20;datacontent:0.0.96.74.15.255;1;2
2020-05-08 14:34:04 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001CA00010000604A0FFF0200
2020-05-08 14:34:07 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:29 Packet:0001000100120015C401CA000A0F000000000000000000000000000000
2020-05-08 14:34:07 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:0;reversed:0;format:;verify:0;datalength:15;datacontent:
2020-05-08 14:34:15 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:34:15 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
2020-05-08 14:34:15 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001CB00010000604A0FFF0200
2020-05-08 14:34:17 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:29 Packet:0001000100120015C401CB000A0F000000000000000000000000000000
2020-05-08 14:34:17 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:36:41 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:36:41 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:19;datacontent:0.0.96.74.9.255;1;2
2020-05-08 14:36:41 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001CC00010000604A09FF0200
2020-05-08 14:36:42 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:29 Packet:0001000100120015C401CC000A0F39352E3231362E32312E3135340000
2020-05-08 14:36:42 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
Param[0]:DataType:9;length:14;Datadots:0;reversed:0;format:;verify:0;datalength:15;datacontent:95.216.21.154
2020-05-08 14:36:42 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:36:42 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:20;datacontent:0.0.96.74.12.255;1;2
2020-05-08 14:36:42 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001CD00010000604A0CFF0200
2020-05-08 14:36:44 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:29 Packet:0001000100120015C401CD000A0F000000000000000000000000000000
2020-05-08 14:36:44 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:36:44 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:36:44 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:20;datacontent:0.0.96.74.60.255;1;2
2020-05-08 14:36:44 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001CE00010000604A3CFF0200
2020-05-08 14:36:46 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:29 Packet:0001000100120015C401CE000A0F000000000000000000000000000000
2020-05-08 14:36:46 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:36:46 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:36:46 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
Param[1]:DataType:1;length:6;Datadots:0;reversed:0;format:;verify:0;datalength:20;datacontent:0.0.96.74.63.255;1;2
2020-05-08 14:36:46 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001CF00010000604A3FFF0200
2020-05-08 14:36:47 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:29 Packet:0001000100120015C401CF000A0F000000000000000000000000000000
2020-05-08 14:36:47 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:36:47 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:36:47 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:2
2020-05-08 14:36:47 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:21 Packet:000100120001000DC001C000010000604A0FFF0200
2020-05-08 14:36:48 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:29 Packet:0001000100120015C401C0000A0F000000000000000000000000000000
2020-05-08 14:36:48 --> - 037205888771 - AnalysizePacket End:28436048 Ret:0
nPrmLen:1
2020-05-08 14:56:30 --> - 037205888771 - PtlInitialize:28436048 initbuf:MODE:0;MODEE:1;AUTHENT:1;CLIENTID:18;PASSWORD:*********;ADDRLEN:1;SERVERLOWERADDRESS:0;SERVERUPPERADDRESS:1;CTRLFLAG:-1;LLCTIMEOUT:0;COSEMPDUSIZE:512;HDLCMAXINFO:0;NOSHAREHAND:0;SECURITYPOLICY:0;AKEY:;EKAY:;ClIENTSYTEMTITLE:;FRAMECOUNT:;DEBUG:1 Ret:0
2020-05-08 14:56:30 --> - 037205888771 - CreatePacket Begin:28436048 nPrmLen:3
2020-05-08 14:56:30 --> - 037205888771 - CreatePacket End:28436048 Ret:1
PacketLen:43 Packet:0001001200010023C101C100010100605001FF02000A143235393938353237343136323734363239363530
2020-05-08 14:56:33 --> - 037205888771 - AnalysizePacket Begin:28436048 nPrmLen:1
PacketLen:12 Packet:0001000100120004C501C10C
2020-05-08 14:56:33 --> - 037205888771 - AnalysizePacket End:28436048 Ret:-6212
Try with settings below:
-s 1 -c 18 -a Low -P 12345678 -w
dsoler
5 years 4 months ago
Hi kurumi,
Hi kurumi,
We're trying to connect with the same meter model 'DTZ1513' and we managed to get the initial connection settings from the manufacturer, which actually are default key values of DLMS. However, we are not able to get a valid AARQ response from the meter.
This is the initial connection string which we are using (Anyway we are also attaching the DLMS Director configuration screenshots):
-h xxx.xxx.xxx.xxx -p xxxxx -c 17 -a Low -P 12345678 -C AuthenticationEncryption -T 49484D01755E1A94 -A 202122232425262728292A2B2C2D2E2F -B 000102030405060708090A0B0C0D0E0F -v 0.0.43.1.2.255 -t Verbose
This is the communication log the software is showing when we try to connect
Send SNRM request.
04:34:41.066 Sent 7E A0 07 03 21 93 0F 01 7E
04:34:41.503 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
RX: 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
04:34:41.503 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
04:34:41.941 Received 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
04:34:41.941 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
04:34:42.456 Received 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1C 90 C2 7E
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1C 90 C2 7E
Disconnect request
04:34:42.456 Sent 7E A0 07 03 21 53 03 C7 7E
04:34:42.878 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send SNRM request.
TX: 7E A0 20 03 25 93 1D BE 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
04:34:42.878 Sent 7E A0 20 03 25 93 1D BE 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
04:34:43.410 Received 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
RX: 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
TX: 7E A0 6B 03 25 10 2C DE E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 35 34 5A 51 41 6F 10 65 79 0C 25 49 79 45 57 71 BE 23 04 21 21 1F 30 00 00 00 1D 66 7E 81 87 D1 78 38 1F 7A C6 D0 C4 C9 C4 72 0A 40 2F 4C B5 D3 88 CF DA 5A DE 31 6F 7E
04:34:43.410 Sent 7E A0 6B 03 25 10 2C DE E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 35 34 5A 51 41 6F 10 65 79 0C 25 49 79 45 57 71 BE 23 04 21 21 1F 30 00 00 00 1D 66 7E 81 87 D1 78 38 1F 7A C6 D0 C4 C9 C4 72 0A 40 2F 4C B5 D3 88 CF DA 5A DE 31 6F 7E
04:34:44.316 Received 7E A0 36 25 03 30 B6 03 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 02 BE 06 04 04 0E 01 06 00 E5 B1 7E
RX: 7E A0 36 25 03 30 B6 03 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 02 BE 06 04 04 0E 01 06 00 E5 B1 7E
04:34:44.316 Sent 7E A0 07 03 25 53 63 A0 7E
04:34:44.816 Received 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
04:34:44.816 Info Closing
04:34:44.816 Info Closed
Thanks in advance,
In reply to Hi kurumi, by dsoler
Hi dsoler,
Hi dsoler,
Please, if you have a new question, create a new topic. I'll answer your question there.
