  3. Connection Is Permanently Rejected. The Application Context Name Is Not Supported.
Connection is permanently rejected. The application context name is not supported.
By Frizull , 30 November, 2019
Gurux.DLMS.AMI
Hi!
Thanks for the great piece of software. I'm trying to get Gurux.DLMS.AMI up and running to read a Landis+Gyr ZMD410 through one of their CU-XE111 IP modems.
Works fine when using GXDLMSDirector, I can read the meter and all its registers.
But then importing the .gxc file as a template and adding in the device in AMI, the console always returns "Connection is permanently rejected. The application context name is not supported."
Initially thought it could be because of Logical Name Referencing, but toggling the switch in the device properties did not help. Do you have any clue as to what could be happening?
Thanks a bunch!
Ian
6 years 11 months ago
Please, don't post images. Send text from the console. It's easirt to check what is wrong.
Your meter is using short name and Gurux.DLMS.AMI seems to use logical name referencing.
We'll checks this and let you know tomorrow.
Frizull
Thanks! I was watching the
Thanks! I was watching the repo on GitHub and noticed there has been some changes commited with regard to short names. Using that latest release, here is what the console looks like now:
TX: 06:36:39 7E A0 07 03 21 93 0F 01 7E
RX: 06:36:39 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
Parsing UA reply.81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01
Parsing UA reply succeeded.
Send AARQ request
TX: 06:36:39 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
RX: 06:36:39 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 6C 2A 7E
Parsing AARE reply61 29 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00
Parsing AARE reply succeeded.
Reading: 39656
TX: 06:36:39 7E A0 11 03 21 32 B7 3D E6 E6 00 05 01 02 9A F8 C2 0C 7E
RX: 06:36:39 7E A0 15 21 03 52 5D 8A E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
Reading: 39656
TX: 06:36:39 7E A0 11 03 21 54 87 3B E6 E6 00 05 01 02 9A F0 8A 80 7E
RX: 06:36:39 7E A0 14 21 03 74 D2 D2 E6 E7 00 0C 01 00 05 00 00 5C 07 CE 90 7E
Send AARQ request
RX: 06:36:40 7E A0 36 21 03 30 D7 60 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 0F 04 0D 08 00 06 5F 04 00 00 00 00 09 60 FA 00 26 1B 7E
Parsing AARE reply61 1F A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 0F 04 0D 08 00 06 5F 04 00 00 00 00 09 60 FA 00
Connection is permanently rejected. No reason is given.
TX: 06:36:40 7E A0 07 03 21 93 0F 01 7E
Thanks again for all your efforts!
Ian
Hi Ian,
Hi Ian,
Get the latest version from GitHub. You need to create a device template again. The old version didn't support Short Name referencing.
Frizull
Hi!
Hi!
Thanks, I was watching the repo yesterday and retried with the new release a few minutes after the changes were pushed. I'm using the in-memory database, so I had to recreate the template and device anyway. My previous response is the result of that test: it now prints "Connection is permanently rejected. No reason is given."
Would you like me to open a separate issue for that new message?
Thanks again!
I.
Do you try to read this manually or are you using a schedule? How many meters you have?
Are you using virtual meters or real meter?
Frizull
I'm trying a manual read for
I'm trying a manual read for now, but will schedule a read each second in the future. The make and model are specified in my first message, and this is a real meter.
I can give you the host and ports if it's useful to you: the meter is reachable over the Internet.
Thanks again,
I.
We found reason for this. Thanks from your help.
http://www.gurux.fi/node/14111
Get the latest version.
  • Victorian | WA 083148835648
