  3. Server Example and Client Example Test Error
Server example and Client example test error
By pangda , 12 November, 2019
Server example
pangda@Ubuntu:~/share/DLMS_C/GuruxDLMS.c/GuruxDLMSServerExample/bin$ ./gurux.dlms.server.bin
Short Name DLMS Server in port 4060.
Example connection settings:
Gurux.DLMS.Client.Example.Net -r sn -h localhost -p 4060
Logical Name DLMS Server in port 4061.
GuruxDLMSClientExample -h localhost -p 4061
Short Name DLMS Server with IEC 62056-47 in port 4062.
GuruxDLMSClientExample -r sn -h localhost -p 4062 -w
Logical Name DLMS Server with IEC 62056-47 in port 4063.
GuruxDLMSClientExample -h localhost -p 4063 -w
Press Enter to close application.
Client example
pangda@Ubuntu:~/share/DLMS_C/GuruxDLMS.c/GuruxDLMSClientExample/bin$ ./gurux.dlms.client.bin -r sn -c 16 -s 1 -h 127.0.0.1 -p 4060 -t Verbose
Connecting to 127.0.0.1:4060
InitializeConnection
<- 7E A0 07 03 21 93 0F 01 7E
-> 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
<- 7E A0 28 03 21 10 36 8A 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 69 1B 7E
-> 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 02 00 04 00 FA 00 1A AF 7E
GetAssociationView
<- 7E A0 0E 03 21 32 EF 4C 05 01 02 FA 08 17 0E 7E
-> 7E A8 86 21 03 52 7F 1B 0C 01 00 01 1A 02 04 10 FA 00 12 00 0C 11 00 09 06 00 00 28 00 00 FF 02 04 10 00 A0 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 04 10 00 B0 12 00 01 11 00 09 06 01 01 00 00 00 FF 02 04 10 00 C0 12 00 01 11 00 09 06 01 01 00 00 01 FF 02 04 10 00 D0 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 04 10 00 E0 12 00 12 11 00 09 06 00 00 2C 00 00 FF 02 04 10 01 40 12 00 03 11 00 09 06 7A 51 7E
<- 7E A0 07 03 21 51 11 E4 7E
-> 7E A8 86 21 03 54 49 7E 01 01 15 19 00 FF 02 04 10 01 70 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 04 10 02 00 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 04 10 02 30 12 00 07 11 00 09 06 01 00 63 01 00 FF 02 04 10 02 A8 12 00 1D 11 00 09 06 00 00 02 01 00 FF 02 04 10 02 D8 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 04 10 03 30 12 00 13 11 00 09 06 00 00 14 00 00 FF 02 04 10 03 78 12 00 05 11 00 09 3D 66 7E
<- 7E A0 07 03 21 71 13 C5 7E
-> 7E A8 86 21 03 56 5B 5D 06 01 00 1F 04 00 FF 02 04 10 03 D0 12 00 15 11 00 09 06 00 00 10 01 00 FF 02 04 10 03 F0 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 04 10 04 10 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 04 10 04 38 12 00 1C 11 00 09 06 00 00 02 02 00 FF 02 04 10 04 68 12 00 1B 11 01 09 06 00 00 02 00 00 FF 02 04 10 04 88 12 00 2B 11 00 09 06 00 00 19 02 00 FF 02 04 10 04 98 12 00 46 11 00 C7 66 7E
<- 7E A0 07 03 21 91 1D 22 7E
-> 7E A0 6B 21 03 58 00 D1 09 06 00 00 60 03 0A FF 02 04 10 04 C8 12 00 2A 11 00 09 06 00 00 19 01 00 FF 02 04 10 05 40 12 00 28 11 00 09 06 00 00 19 09 00 FF 02 04 10 05 80 12 00 09 11 00 09 06 00 00 0A 00 00 FF 02 04 10 05 A8 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 04 10 05 F0 12 00 3E 11 00 09 06 00 00 42 00 01 FF A8 CE 7E
<- 7E A0 11 03 21 B4 89 DC 05 02 02 01 50 02 03 90 FF 1E 7E
-> 7E A0 1F 21 03 7A B9 FB 0C 02 00 02 02 0F FE 16 1E 00 02 02 0F 00 16 00 C8 12 00 2A 11 00 8C 13 7E
<- 7E A0 0E 03 21 D6 C5 ED 05 01 02 01 50 7A 48 7E
-> 7E A0 12 21 03 9C 0E F2 0C 01 00 02 02 0F FE 16 1E F2 C6 7E
<- 7E A0 0E 03 21 F8 B9 25 05 01 02 03 90 C6 BD 7E
-> 7E A0 12 21 03 BE 1E F0 0C 01 00 02 02 0F 00 16 00 22 A3 7E
<- 7E A0 0E 03 21 1A A5 E1 05 01 02 02 40 93 72 7E
-> 7E A0 32 21 03 D0 35 F5 0C 01 00 01 02 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 15 19 00 FF 0F 02 12 00 00 22 CD 7E
-------- Reading Object Association Short Name 00.00.40.00.00.255
<- 7E A0 0E 03 21 3C 91 A5 05 01 02 FA 08 17 0E 7E
-> 7E A8 86 21 03 F2 75 BE 0C 01 00 01 1A 02 04 10 FA 00 12 00 0C 11 00 09 06 00 00 28 00 00 FF 02 04 10 00 A0 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 04 10 00 B0 12 00 01 11 00 09 06 01 01 00 00 00 FF 02 04 10 00 C0 12 00 01 11 00 09 06 01 01 00 00 01 FF 02 04 10 00 D0 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 04 10 00 E0 12 00 12 11 00 09 06 00 00 2C 00 00 FF 02 04 10 01 40 12 00 03 11 00 09 06 7A 51 7E
-> 7E A8 86 21 03 F4 43 DB 01 01 15 19 00 FF 02 04 10 01 70 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 04 10 02 00 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 04 10 02 30 12 00 07 11 00 09 06 01 00 63 01 00 FF 02 04 10 02 A8 12 00 1D 11 00 09 06 00 00 02 01 00 FF 02 04 10 02 D8 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 04 10 03 30 12 00 13 11 00 09 06 00 00 14 00 00 FF 02 04 10 03 78 12 00 05 11 00 09 3D 66 7E
-> 7E A8 86 21 03 F6 51 F8 06 01 00 1F 04 00 FF 02 04 10 03 D0 12 00 15 11 00 09 06 00 00 10 01 00 FF 02 04 10 03 F0 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 04 10 04 10 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 04 10 04 38 12 00 1C 11 00 09 06 00 00 02 02 00 FF 02 04 10 04 68 12 00 1B 11 01 09 06 00 00 02 00 00 FF 02 04 10 04 88 12 00 2B 11 00 09 06 00 00 19 02 00 FF 02 04 10 04 98 12 00 46 11 00 C7 66 7E
-> 7E A0 6B 21 03 F8 0A 74 09 06 00 00 60 03 0A FF 02 04 10 04 C8 12 00 2A 11 00 09 06 00 00 19 01 00 FF 02 04 10 05 40 12 00 28 11 00 09 06 00 00 19 09 00 FF 02 04 10 05 80 12 00 09 11 00 09 06 00 00 0A 00 00 FF 02 04 10 05 A8 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 04 10 05 F0 12 00 3E 11 00 09 06 00 00 42 00 01 FF A8 CE 7E
<- 7E A0 0E 03 21 BE 8B 02 05 01 02 FA 10 DE 92 7E
-> 7E A0 0C 21 03 1A D3 7E 0C 01 01 85 62 7E
ReadObject failed Association Short Name 00.00.40.00.00.255:3 Not enough memory available.
Failed to read object Association Short Name 00.00.40.00.00.255 attribute index 3
<- 7E A0 07 03 21 53 03 C7 7E
Error.All items are read.
ERROR: the test result show "Not enough memory available.".
I want to know why the error occur, and how to Analysis the communication of processes.
how to know the detail and the function for this client example and the server example?
is there a detailed introduction about these two example?
7 years ago
It seems that we have broke Short Name referencing. All companies are using Logical Name referencing nowadays. We are testing this and release a new version today.
7 years ago
Get the latest version from the GitHub. obj_attributeCount returned wrong attribute index count for gxAssociationShortName.
pangda
7 years ago
thanks
thanks
