  3. I Got AARQRequest Failed 252
I got AARQRequest failed 252
By lofna , 24 October, 2019
I am using Sprint 350 established the connection via serial port and got the below
error.
InitializeConnection
AARQRequest failed 279.
cat trace.txt
TX: 18:06:48 7E A0 07 03 21 93 0F 01 7E
RX: 18:06:48 7E A0 20 21 03 73 73 98 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
TX: 18:06:48 7E A0 44 03 21 10 E6 84 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 1D 76 7E
RX: 18:06:48 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 0F 53 7E
TX: 18:06:48 7E A0 07 03 21 53 03 C7 7E
Without authentication i am getting the meter specific information which i have mentioned below the log.
./gurux.dlms.client.bin -S /dev/ttyUSB0 9600
GetAssociationView
-------- Reading GXDLMSAssociationLogicalName 0.0.40.0.0.255
Index: 2 Value: [0.0.40.0.0.255, 0.0.40.0.1.255, 1.0.0.0.6.255, 1.0.96.160.0.255, 1.0.0.0.1.255, 0.0.96.1.0.255, 0.0.42.0.0.255, 0.0.1.0.0.255]
Index: 3 Value: 16/1
Index: 4 Value: 0 0 0 5 8 1 1
Index: 5 Value: 16 512 1024 6 0
Index: 6 Value: 0 0 0 5 8 2 0
Index: 8 Value: 2
-------- Reading GXDLMSAssociationLogicalName 0.0.40.0.1.255
Index: 8 Value: 2
-------- Reading GXDLMSData 1.0.0.0.6.255
Index: 2 Value: 69.83.76.45.48.48.50
-------- Reading GXDLMSData 1.0.96.160.0.255
Index: 2 Value: {{1.0.1.8.0.255, 134}, {1.0.2.8.0.255, 133}, {1.0.5.8.0.255, 150}, {1.0.6.8.0.255, 152}, {1.0.7.8.0.255, 151}, {1.0.8.8.0.255, 149}, {1.0.9.8.0.255, 161}, {1.0.10.8.0.255, 165}, {1.0.1.128.0.255, 208}, {1.0.16.8.0.255, 240}}
-------- Reading GXDLMSData 1.0.0.0.1.255
Index: 2 Value: 77.50.88.55.71.48.67
-------- Reading GXDLMSData 0.0.96.1.0.255
Index: 2 Value: 73.80.76.68.48.49.55.48
-------- Reading GXDLMSData 0.0.42.0.0.255
Index: 2 Value: 69.72.76.69.51.68.120.120.120
-------- Reading GXDLMSClock 0.0.1.0.0.255
Index: 2 Value: 10/24/2019 18:22:56
When i am using authentication mode i am getting
AARQRequest failed 252.
What could be the issue, how can i over come this issue. Here i am using usb to serial cable (FTDI).
I am using Indian standard with this command failed: (./gurux.dlms.client.bin -S /dev/ttyUSB0 -c 20 -s 1 -a Low -P ABCD0001)
Lofna
7 years 1 month ago
You have to change client address. Now it's 0x10 and this is used when authentication is not used. Try to change it to 0x20.
lofna
7 years 1 month ago
Thanks for your suggestions. Now i am getting the meter information that get stored under Log file.
how can i read the specific parameters from this Gurux library calls. Parameters mean voltage, current, frequency, power factor values. because i am new to dlms.
Now i got the total registers data get logged under log file.
How can i retrieve the particular parameters to read and display in readable/understandable decimal format.i am running this under arm linux platform.
regards,
lofna
7 years 1 month ago
You need to know the object interface type and OBIS code. When you know this, you can read that value.
Something like:
CGXDLMSClock clock("0.0.1.0.0.255");
read(clock, 2);
clock.GetTime()
shgandhi
4 years 6 months ago
hi ,
hi ,
I am communicating meter with optical cable and using gurux c code, but i got this error please help.
sudo ./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 16 -s 1
GetAssociationView
-------- Reading Object AssociationLogicalName 0.0.40.0.1.255
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:7 Access Error : Device reports scope of access violated.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 7
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:9 Access Error : Device reports a unavailable object.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 9
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:10 Access Error : Device reports a unavailable object.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 10
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:11 Access Error : Device reports a unavailable object.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 11
In reply to hi , by shgandhi
Hi shgandhi,
Hi shgandhi,
You need to create a new topic. I'll answer your question after you have created a new topic.
