  3. How Could I Read Proper Format For Scalars and Units of a Profile Generic Object?
How could I read proper format for scalars and units of a profile generic object?
By pradson , 9 October, 2019
Kindly refer below mentioned code:
CGXDLMSProfileGeneric *obj = new CGXDLMSProfileGeneric("1.0.94.91.3.255");
std::string sValues;
if ((ret = comm.Read(obj, 3, sValues)) != 0){
TRACE("err! failed to read register: %s \n", CGXDLMSConverter::GetErrorMessage(ret));
sValues.clear();
if ((ret = comm.Read(obj, 2, sValues)) != 0){
OutPut:
{-3, 33, } | {-3, 33, } | {-3, 33, } | {-2, 35, } | {-2, 35, } | {-2, 35, } | {-3, 255, } | {-3, 255, } | {-3, 255, } | {-3, 255, } | {-2, 44, } | {0, 28, } | {0, 27, } | {0, 29, } | {-1, 30, } | {-1, 30, } | {-1, 31, } | {-1, 31, } | {0, 6, } | {0, 255, } | {0, 27, } | {0, 27, } | {0, 27, } |
But when I read the same using DLMSDirector application, then I get the below mentioned output.
{0.001, Current} {0.001, Current} {0.001, Current} {0.01, Voltage} {0.01, Voltage} {0.01, Voltage} {0.001, NoUnit} {0.001, NoUnit} {0.001, NoUnit} {0.001, NoUnit} {0.01, Frequency} {1, ApparentPower} {1, ActivePower} {1, ReactivePower} {0.1, ActiveEnergy} {0.1, ActiveEnergy} {0.1, ApparentEnergy} {0.1, ApparentEnergy} {1, Minute} {1, NoUnit} {1, ActivePower} {1, ActivePower} {1, ActivePower}
How could I get this type of format?
Kindly suggest me.
Thanks & Regards
Pradson
pradson
7 years 1 month ago
I observed scalars values like-
0 represents 1
-1 represents 0.1
-2 represents 0.01
-3 represents 0.001
etc..etc...
Am I right?
7 years 1 month ago
Scaler is pow(10, X), where X is read number. So you are right. ANSI C++ don't convert read values to the string, you must do it by your self at the moment.
pradson
7 years 1 month ago
and what about units?
How could I convert-
33 to "Current"
35 to "Voltage"
255 to "NoUnit"
44 to "Frequency"
etc...etc...
I mean,
Is any method which convert numeric units to string units in Gurux?
7 years 1 month ago
You can use CGXDLMSConverter::GetUnitAsString -method for that.
pradson
7 years 1 month ago
Thanks a lot for your kind help.
Thanks & Regards,
Pradson
