  3. Fail To Upload Firmware Image
Fail to upload firmware image
By AndreasAtPowel , 23 September, 2019
We're trying to upload a firmware image to Star meters using low level security, which should be supported according to Star. Even using High level security we get same error.
We're following your example on how to upload an image.
Below is the sequense:
- Check that image transfer is enabled.
Write 21 bytes, 000100010005000DC00141001200002C0000FF0500
Received 14 bytes, 0001000500010006C40141000301
- Read image block size.
Write 21 bytes, 000100010005000DC00141001200002C0000FF0200
Received 17 bytes, 0001000500010009C401410006000000C8
- Initiate the Image transfer process.
Write 35 bytes, 000100010005001BC30141001200002C0000FF01010202090556303230310600024A86
Received 13 bytes, 0001000500010005C701410000
- Transfers ImageBlocks.
Write 136 bytes, 0001000100050080C30141001200002C0000FF020100000000016D020206000000000981C8AE91000000005A660CD2023E8AFA732F0FCAE7CD1ACDB9A9C2E46F5CCF905746725A0DCD543FB26C4B36F00F90A97C0C4467A781CECE6369099A99640624E071711EED89B9F39F3FF8205639EDE0A10F257C46817D5A4FF4A42F777B4F72CE6446332E
Received 13 bytes, 0001000500010005C70141FA00
Write 10 bytes, 00010001000500026200
Received 31 bytes, 00010005000100176315800100BE10040E0800065F1F0400001A1D00800007
When translating the failing 136 bytes block I get this from your translator, no method parameters:
<ActionRequest>
<ActionRequestNormal>
<!--Priority: NORMAL ServiceClass: CONFIRMED invokeID: 1-->
<InvokeIdAndPriority Value="65" />
<MethodDescriptor>
<!--IMAGE_TRANSFER-->
<ClassId Value="18" />
<!--0.0.44.0.0.255-->
<InstanceId Value="00002C0000FF" />
<MethodId Value="2" />
</MethodDescriptor>
<MethodInvocationParameters>
<None />
</MethodInvocationParameters>
</ActionRequestNormal>
</ActionRequest>
Any sugestions on what wer're doing wrong?
7 years 2 months ago
Are you doing this with Java or C#? We'll check this.
AndreasAtPowel
C#
C#
Are you using ImageTransferInitiate and ImageBlockTransfer -methods of GXDLMSImageTransfer to send the image or are you generating Transfers ImageBlocks by your self?
AndreasAtPowel
Yes,we're following your
Yes,we're following your example code, from our code:
var target = new GXDLMSImageTransfer(firmwareImageTransferLogicalName);
var readData = _guruxPacketHandler.GxDlmsClient.Read(target, TRANSFER_ENABLED_ATTRIBUTE);
var reply = _guruxPacketHandler.SendAndReceive(readData);
_guruxPacketHandler.GxDlmsClient.UpdateValue(target, TRANSFER_ENABLED_ATTRIBUTE, reply.Value);
readData = _guruxPacketHandler.GxDlmsClient.Read(target, BLOCK_SIZE_ATTRIBUTE);
_guruxPacketHandler.GxDlmsClient.UpdateValue(target, BLOCK_SIZE_ATTRIBUTE, reply.Value);
readData = target.ImageTransferInitiate(_guruxPacketHandler.GxDlmsClient, imageIdentifier, imageData.Length);
readData = target.ImageBlockTransfer(_guruxPacketHandler.GxDlmsClient, imageData, out var imageBlockCount);
Image block size if 200. When you write the first image block it's size is much smaller.
Can you send AARQ/AARE messages to me by email?
Send also Gurux.DLMS.dll version number.
AndreasAtPowel
email sent to gurux@gurux.org
email sent to [Email removed by admin].
