  3. CEWE Prometer
CEWE Prometer
By Danlew2018 , 14 November, 2018
Has anyone got any general advice on how to talk to a CEWE Prometer using GXDLMSDirector?
It’s not listed as a meter in the dropdown menus.
Thanks in advance
8 years ago
CEWE Prometer 100
If the meter is CEWE Prometer 100 you can try to communicate with it using Gurux as a manufacturer.
Let me know if you have problems.
Danlew2018
8 years ago
It’s the old Cewe Prometer, not the Prometer 100 although I will be getting the new Prometer soon so thanks for the advice.
Dan
michaelito80
7 years 10 months ago
Prometer 100
Hi Mikko
I'm trying to connect with GXDLMSDirector to promise 100, but I can't connect.
What parameters should I enter in Manufacturer, Address Type, Physical server?
Best regards
Prometer 100
Select Gurux as a manufacturer and try. Let me know if you have problems.
michaelito80
Prometer 100
Yes, I have problems, I can't connect to meter.I need the configuration parameters, I have serial number, IP, port but I think I'm missing something to configure
Prometer 100
Select Gurux as a manufacturer and change Interface from HDLC to WRAPPER.
You can find this from the "Advanced" -tab.
Try first connect without authentication (Authentication = None).
michaelito80
Prometer
I still can't to connect, I attach screenshot of my configure, can you check it?
http://es.tinypic.com/r/zmjsk5/9
http://es.tinypic.com/r/qycmxl/9
Thanks for you help.
Best Regards
