  3. Gurux.DLMS For .NET Core Failed To Initialize Net Connection
Gurux.DLMS for .NET Core failed to initialize net connection
By khun_panya , 3 August, 2018
Hi. Great to see Gurux.DLMS now available for .NET Core.
But I can't get it to work right now.
I made a simple .NET Core console app using VS2017.
Get the Gurux.Common, Gurux.DLMS and Gurux.Net via NuGet.
And use a slightly modification of GXDLMSReader taken from the client example for .NET Framework.
Here is my code
var Manufacturers = new GXManufacturerCollection();
GXManufacturerCollection.ReadManufacturerSettings(Manufacturers);
var man = Manufacturers.FindByIdentification("lgz");
var dlms = new Gurux.DLMS.Secure.GXDLMSSecureClient();
dlms.CustomObisCodes = man.ObisCodes;
var media = new Gurux.Net.GXNet(Gurux.Net.NetworkType.Tcp, "192.168.0.120", 6001);
media.Open();
var reader = new GXDLMSReader(dlms, media, TraceLevel.Info);
reader.InitializeConnection();
reader.GetAssociationView(false);
if (reader != null)
reader.Close();
The code above works perfectly for .NET Framework.
But for .NET core, it stuck at the line InitializeConnection.
Here is the error detail
System.Net.Sockets.SocketException
HResult=0x80004005
Message=A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied
Source=Gurux.Net
StackTrace:
at Gurux.Net.GXNet.Send(Object data, String receiver)
Any suggestion or any client example for .NET Core specifically?
Thanks.
8 years 3 months ago
This is tested in Windows and it works without problems. What operating system you are using?
khun_panya
In reply to Gurux.DLMS for .NET Core failed to initialize net connection by Kurumi
It is Windows 10 Pro
It is Windows 10 Pro build 1709.
I'd placed a sample project for further investigation here if you like
https://1drv.ms/u/s!AnPKv5Tv5gkOlrxVct1llMmE61WKVg
Gurux.DLMS for .NET Core failed to initialize net connection§
Can you connect with GXDLMSDirector? Check your IP address and port number.
khun_panya
In reply to Gurux.DLMS for .NET Core failed to initialize net connection§ by Kurumi
Yes
I can use GXDLMSDirector to read the meter. IP and port is correct.
The same code in .NET Framework also works fine.
Has problem only when use .NET Core.
No matter I run VS2017 (15.7.3) as admin or normal user.
We made one change to Gurux.Net component.
Update version to 8.1.1808.701.
Let me know if you still have problems.
khun_panya
Splendid!
The updated version works perfectly.
Thanks to you guys.
