  3. I Am Getting This Error While Reading Billing Profile For Selective Read
i am getting this error while reading Billing profile for selective read
By erdeepakcs , 20 June, 2017
Hi Sir,
Request: 20-06-2017 PM 04:01:13.83564 (+6.3064 seconds)
7E A0 2C 03 41 54 AF 99 E6 E6 00 C0 01 C1 00 07
01 00 62 01 00 FF 02 01 02 02 04 06 00 00 00 01
06 00 00 00 01 12 00 01 12 00 00 36 D2 7E
Answer: 20-06-2017 PM 04:01:13.88664 (+0.0510 seconds)
7E A0 07 41 03 1F 26 EC 7E
i am sending this command to reading billing profile for selective read by Entry. please can you explain why this error is coming.
9 years 3 months ago
Billing profile
Message is correct:
http://www.gurux.fi/GuruxDLMSTranslator?pdu=C001C100070100620100FF02010…
You was not saying what meter you try to read. All meters don't implement read by entry(index and count). Try with read by range(between start and end date).
Binu S Pillai
8 years 10 months ago
How to get PROFILE GENERIC values in android DLMS
I am reading the data from meter using optical probe. How can i read the Profile Generic values for selective read like in gurux director in android. When i read the profile generic values(Obis codes of profile generic: 1.0.98.1.0.255) in the gurux director with read all option it was returning a list. Like wise how can i read profile generic obis codes in android. Please help me with this.
You have to modify source code. Our example reads all data at the moment and there are no start and end time on UI.
You can modify read method and check is object profile generic.
* Reads profile generic using start and end time.
* @param item
* @param attributeIndex
* @return
* @throws Exception
public void readRowsByRange(final GXDLMSProfileGeneric pg,
final Date start, final Date end) throws Exception {
byte[][] data = mClient.readRowsByRange(pg, start, end);
readDataBlock(data, reply);
mClient.updateValue(pg, 2, reply.getValue());
public void read(GXDLMSObject obj) throws Exception {
if (obj instanceof GXDLMSProfileGeneric)
readRowsByRange((GXDLMSProfileGeneric)obj, start time, end time) ;
else{
for (int it : ((IGXDLMSBase) obj).getAttributeIndexToRead()) {
readObject(obj, it);
Binu S Pillai
In reply to How to get PROFILE GENERIC values in android DLMS by Kurumi
I got it, Will you send me some example code with profile generic data reading.
Binu S Pillai
In reply to How to get PROFILE GENERIC values in android DLMS by Binu S Pillai
Hai,
I tried your code thank you for saving me, Sorry to disturbing you again and again I want to read ALL the profile generic values insted of from date, to date how can i do that
Thank you,
Hi.
Read buffer using read-method. That reads all data from the DB.
Like this:
//Read capture objects.
Read(pg, 3);
//Read ALL data.
Read(pg, 2);
Binu S Pillai
Hai,
I had wrote the code like this but it wasn't returning any values for profile generic can you tell me why.
Please correct me if i am wrong
GXReplyData reply_data = new GXReplyData();
if(obj instanceof GXDLMSProfileGeneric){
byte[][]temp;
CurrentProfileGeneric = (GXDLMSProfileGeneric) obj ;
temp = mClient.read(CurrentProfileGeneric,2);
readDataBlock(temp,reply_data);
}else {
Read captured columns first. Something like:
readObject(pg, 3);
