  3. 2xLandis+Gyr E650 + CU-P42 + CU-E22
By Cavantar , 10 May, 2017
I have 2 landis+gyr e650 devices.
My pc is connected to one landis+gyr e650 through CU-E22 using ethernet.
The first landis gyr is connected with serial interface to the second - CU-E22 -> CU-P42 - which are configured as master -> slave.
I can use DLMSDirector to connect to one of the devices - the master.
I tried setting Logical Server addres to 1, but I couldn't connect to the second device.
What's the procedure for accessing second - slave device using dlms director ?
Any hints would be appreciated.
9 years 1 month ago
You need to use meter's serial number as meter address.
dntimmie
6 years 3 months ago
Ok. Use the serial numbers,
Ok. Use the serial numbers, but what do I do with physical address, logical address and useLogicalNameReferencing? I connect to the meters via IP dlms (CU-L52 and CU-B2) and I get the message: No connection could be made because the target machine actively refused it. What is the problem?
In reply to Ok. Use the serial numbers, by dntimmie
Hi dntimmie,
Hi dntimmie,
