  3. Unable To Connect To Remore Server While Downloading New Manufacturer Settings
unable to connect to remore server while downloading new manufacturer settings
By neelam naik , 14 July, 2016
I downloaded GuruX Director installer and installed it on my Windows 7 machine.
But when I run the application it shows me the new manufacturer settings Available and when I try to update them online then it shows error of unable to connect to server.
Please guide to resolve this issue.
Windows 7, 32 bit.
10 years 4 months ago
I checked this and it worked like should be.
Usually problem is that there is antivirus software or firewall that is blocking the connection.
Can you check those?
vlnau
8 years 3 months ago
In reply to unable to connect to remore server while downloading new manufac by Kurumi
manufacturers online update error
I've got the same issue. It seems to me that it cannot be overcome. Are there any other ways to update the list?
vlnau
The reply is "The remote server returned an error: (407) Proxy Authentication Required"
I try this with empty PC and it worked. Can you check can you access this from your web browser?
Are you using proxy?
http://www.gurux.fi/obis/files.xml
vlnau
Thank you for your help!
Unfortunately I'm using proxy and my sysadm can't help me.
I can't download files from browser, I only can see a list of them.
Is it possible to download zip-file somehow and then to unzip it at my PC?
We are releasing new version today where we have improved this. I hope it fixes your problem.
It's out after one hour.
vlnau
In reply to manufacturers online update error by Kurumi
Now everything is good. Thank you so much!
Thanks from this info. I'm glad it helped.
dinesh
6 years 10 months ago
Dear Sir, I have the same
Dear Sir, I have the same issue of downloading GXDLMSDirector for .Net but through Server Proxy. I am getting the message 407 Proxy Authentication required. I am sure I have given necessary proxy details in Windows Server 2012. Is there any method to overcome this or any offline download available ? Kindly suggest me.
In reply to Dear Sir, I have the same by dinesh
Dear Sir,
Dear Sir,
