  3. Surovsv
surovsv
By surovsv , 9 February, 2016
Error reading.
Hi!
After installing version 8.0.0.5 can not read the answer Aare.
The parameters are the following:
-Media: Serial
-Client Address: 0x10
-Physical Server: 0x11
-Logical Server: 1
Log created 13:52:24
13:52:26 Initializing serial connection.
13:52:26 Send SNRM request.
7E A0 08 02 23 21 93 BD 64 7E
13:52:26 Received data
7E A0 1F 21 02 23 73 E6 C7 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
13:52:26 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
13:52:26 Parsing UA reply succeeded.
13:52:26 Send AARQ request
7E A0 2C 02 23 21 10 AF 9F E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 99 C8 7E
7E A0 38 21 02 23 01 3E C7 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 30 1D 19 00 00 07 0C 52 7E
13:52:26 Parsing AARE reply<CR><LF>E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 30 1D 19 00 00 07
13:52:26 Disconnect request
7E A0 08 02 23 21 53 B1 A2 7E
13:52:27 Received data
7E A0 0A 21 02 23 0F 19 EC 47 0F 7E
System.ArgumentOutOfRangeException: Требуется неотрицательное число (It requires non-negative number).
Имя параметра (parameter name): count
в GXDLMSDirector.GXDLMSDevice.InitializeConnection() в C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:строка (line) 374
в GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) в C:\Projects\GXDLMSDirector\Development\MainForm.cs:строка (line) 929
Thanks!
10 years 9 months ago
AARE
What meter you are using? AARE Frame that meter returns is not correct.
Do you remember was server side 4 bytes long earlier?
surovsv
What server side 4 bytes long
What server side 4 bytes long?
Thanks!
AARE
Can you read your meter with older version?
If you can, can you send it's trace to me?
You can find my contact info from here:
http://www.gurux.fi/AboutUs
What meter you try to read?
