  3. Error Reading
Error reading
By dlmsmaniac , 4 February, 2016
Hi!
I have a L+G meter and I can communicate with it perfectly without Authentication. But I want to read energy consumption and then I have to connect with Authentication. The manufacturer give me the reading key, that is 00000001.
The problem is when I write this key as Low or High Authentication because I receive the next message: Connection is permanently rejected. Authentication is required.
The parameters are the following:
-Media: Serial
-Client Address: 10
-Physical Server: 1
-Logical Server: 0
This is the log:
12:11:16 Initializing serial connection.
12:11:16 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
12:11:16 Received data
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
12:11:16 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
12:11:16 Parsing UA reply succeeded.
12:11:16 Send AARQ request
7E A0 44 03 21 10 E6 84 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 0A 80 08 30 30 30 30 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 04 05 7E
7E A0 25 21 03 30 BB 86 E6 E7 00 61 17 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0E 35 7D 7E
12:11:16 Parsing AARE reply<CR><LF>61 17 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0E
12:11:16 Disconnect request
Gurux.DLMS.GXDLMSException: Connection is permanently rejected. Authentication is required.
en GXDLMSDirector.GXDLMSDevice.InitializeConnection() en C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:línea 374
en GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) en C:\Projects\GXDLMSDirector\Development\MainForm.cs:línea 929
Thanks!
10 years 9 months ago
Error reading
It seems that you are using High Authentication level. Try to change it to Low.
See problem with High authentication level for L+G here:
dlmsmaniac
In reply to Error reading by Kurumi
Hi!
Hi!
Firstly, thanks for answer so quick.
I have used Low authentication too, however I get the same error. I don´t understand why.
Best regards!
Error reading
You did not say what is model of your meter, but try to increase client id by one.
dlmsmaniac
The model is L+G ZCXe110CR,
The model is L+G ZCXe110CR, single-phase.
If I increase client ID to 11(hex), I receive this message: "Referencia a objeto no establecida como instancia de un objeto." In English, Object reference do not set as an object instance.
dlmsmaniac
Hi again!
Hi again!
I have a new configuration from technical department of L+G and I have gotten different information without Authentication. Although I have tried to connect with the reading key and client ID 11 and I have had the same error.
- Authentication: None
- Media: Serial
- Wait time: 7
- Client Address: 10
- Physical Server: 10
- Logical Server: 1
The log is the following:
Log created 9:46:14
9:46:49 Initializing serial connection.
9:46:49 Send SNRM request.
7E A0 08 02 21 21 93 05 D1 7E
9:46:50 Received data
7E A0 1F 21 02 21 73 56 F4 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
9:46:50 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
9:46:50 Parsing UA reply succeeded.
9:46:50 Send AARQ request
7E A0 2C 02 21 21 10 17 2A E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 99 C8 7E
7E A0 38 21 02 21 30 84 D4 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1F 00 F8 00 07 DE 98 7E
9:46:50 Parsing AARE reply<CR><LF>61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1F 00 F8 00 07
9:46:50 Parsing AARE reply succeeded.
9:46:52 Read object type Data index: 2
7E A0 1A 02 21 21 32 4E C7 E6 E6 00 C0 01 81 00 01 00 00 60 0A 07 FF 02 00 41 7D 7E
9:46:52 Received data
7E A0 13 21 02 21 52 ED B3 E6 E7 00 C4 01 81 00 11 00 AC 5B 7E
9:46:52 Read object type SapAssignment index: 2
7E A0 1A 02 21 21 54 7E C1 E6 E6 00 C0 01 81 00 11 00 00 29 00 00 FF 02 00 FE BE 7E
9:46:53 Received data
7E A0 2B 21 02 21 74 28 79 E6 E7 00 C4 01 81 00 01 01 02 02 12 00 01 09 11 4C 47 5A 30 30 30 30 30 33 31 30 35 39 32 34 36 00 62 F2 7E
9:46:53 Read object type Data index: 2
7E A0 1A 02 21 21 76 6E C3 E6 E6 00 C0 01 81 00 01 00 00 60 0A 08 FF 02 00 B8 CF 7E
7E A0 13 21 02 21 96 C5 33 E6 E7 00 C4 01 81 00 11 00 AC 5B 7E
7E A0 1A 02 21 21 98 1E CD E6 E6 00 C0 01 81 00 01 00 00 60 01 07 FF 02 00 AD 3A 7E
7E A0 14 21 02 21 B8 65 CB E6 E7 00 C4 01 81 00 09 01 41 47 96 7E
7E A0 1A 02 21 21 BA 0E CF E6 E6 00 C0 01 81 00 01 00 00 60 01 05 FF 02 00 DB 03 7E
7E A0 2B 21 02 21 DA 5C 35 E6 E7 00 C4 01 81 00 09 18 44 65 75 69 63 65 20 49 44 20 36 00 00 00 00 00 00 00 00 00 00 00 00 00 4E C7 7E
7E A0 1A 02 21 21 DC 3E C9 E6 E6 00 C0 01 81 00 01 00 00 60 01 04 FF 02 00 60 1F 7E
7E A0 20 21 02 21 FC 84 36 E6 E7 00 C4 01 81 00 09 0D 4C 47 5A 30 30 33 31 30 35 39 32 34 36 BC 91 7E
7E A0 1A 02 21 21 FE 2E CB E6 E6 00 C0 01 81 00 01 00 00 60 01 03 FF 02 00 41 48 7E
7E A0 27 21 02 21 1E 44 C2 E6 E7 00 C4 01 81 00 09 14 44 65 75 69 63 65 20 49 44 20 34 00 00 00 00 00 00 00 00 00 A1 F8 7E
7E A0 1A 02 21 21 10 5E C5 E6 E6 00 C0 01 81 00 01 00 00 60 01 02 FF 02 00 FA 54 7E
7E A0 25 21 02 21 30 B0 1C E6 E7 00 C4 01 81 00 09 12 63 6F 6E 74 61 64 6F 72 20 20 44 4C 4D 53 30 31 30 36 E2 FA 7E
7E A0 1A 02 21 21 32 4E C7 E6 E6 00 C0 01 81 00 01 00 00 60 01 01 FF 02 00 37 71 7E
9:46:54 Received data
7E A0 19 21 02 21 52 45 FF E6 E7 00 C4 01 81 00 09 06 20 43 59 4E 31 35 FC F0 7E
9:46:54 Read object type Data index: 2
7E A0 1A 02 21 21 54 7E C1 E6 E6 00 C0 01 81 00 01 00 00 60 01 00 FF 02 00 8C 6D 7E
7E A0 1D 21 02 21 74 61 96 E6 E7 00 C4 01 81 00 09 0A 30 30 33 31 30 35 39 32 34 36 20 62 7E
7E A0 1A 02 21 21 76 6E C3 E6 E6 00 C0 01 81 00 01 00 00 60 01 06 FF 02 00 16 26 7E
7E A0 18 21 02 21 96 29 74 E6 E7 00 C4 01 81 00 09 05 56 30 35 32 32 BA 12 7E
7E A0 1A 02 21 21 98 1E CD E6 E6 00 C0 01 81 00 01 01 00 00 02 00 FF 02 00 4E 76 7E
7E A0 18 21 02 21 B8 55 BC E6 E7 00 C4 01 81 00 09 05 56 30 35 32 32 BA 12 7E
7E A0 1A 02 21 21 BA 0E CF E6 E6 00 C0 01 81 00 01 00 00 2A 00 00 FF 02 00 17 4D 7E
7E A0 23 21 02 21 DA 7C 6F E6 E7 00 C4 01 81 00 09 10 4C 47 5A 30 30 30 30 30 33 31 30 35 39 32 34 36 41 27 7E
9:46:54 Read object type Clock index: 2
7E A0 1A 02 21 21 DC 3E C9 E6 E6 00 C0 01 81 00 08 00 00 01 00 00 FF 02 00 65 D7 7E
7E A0 1F 21 02 21 FC A9 88 E6 E7 00 C4 01 81 00 09 0C 07 E0 02 09 02 09 2C 10 00 80 00 04 3A 43 7E
9:46:55 Read object type AssociationLogicalName index: 2
7E A0 1A 02 21 21 FE 2E CB E6 E6 00 C0 01 81 00 0F 00 00 28 00 01 FF 02 00 2F 82 7E
9:46:55 Received data
7E A0 70 21 02 21 1E FA 87 E6 E7 00 C4 02 81 00 00 00 00 01 00 59 01 10 02 04 12 00 01 11 00 09 06 00 00 60 0A 07 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 08 FF 02 02 BC 84 7E
9:46:55 Get Next Data block:
7E A0 14 02 21 21 10 E6 A4 E6 E6 00 C0 02 81 00 00 00 01 73 7F 7E
7E A0 74 21 02 21 30 96 62 E6 E7 00 C4 02 81 00 00 00 00 02 00 5D 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 07 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 05 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 9D 4C 7E
7E A0 14 02 21 21 32 F6 A6 E6 E6 00 C0 02 81 00 00 00 02 E8 4D 7E
7E A0 74 21 02 21 52 82 22 E6 E7 00 C4 02 81 00 00 00 00 03 00 5D 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 03 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 02 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 FD 3B 7E
7E A0 14 02 21 21 54 C6 A0 E6 E6 00 C0 02 81 00 00 00 03 61 5C 7E
9:46:56 Received data
7E A0 73 21 02 21 74 6A 56 E6 E7 00 C4 02 81 00 00 00 00 04 00 5C 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 06 FF F9 54 7E
9:46:56 Get Next Data block:
7E A0 14 02 21 21 76 D6 A2 E6 E6 00 C0 02 81 00 00 00 04 DE 28 7E
7E A0 71 21 02 21 96 FE 84 E6 E7 00 C4 02 81 00 00 00 00 05 00 5A 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 D5 C6 7E
7E A0 14 02 21 21 98 A6 AC E6 E6 00 C0 02 81 00 00 00 05 57 39 7E
7E A0 72 21 02 21 B8 4E 51 E6 E7 00 C4 02 81 00 00 00 00 06 00 5B 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 09 16 00 00 02 03 0F 08 16 00 00 02 03 0F 07 16 00 00 02 03 0F 06 16 00 00 02 03 0F 05 16 00 00 02 03 0F 04 16 00 00 02 03 0F 03 16 00 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 0F 11 01 DB F3 7E
7E A0 14 02 21 21 BA B6 AE E6 E6 00 C0 02 81 00 00 00 06 CC 0B 7E
7E A0 74 21 02 21 DA C2 2A E6 E7 00 C4 02 81 00 00 00 00 07 00 5D 09 06 00 00 28 00 01 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 00 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 08 AF 0A 7E
7E A0 14 02 21 21 DC 86 A8 E6 E6 00 C0 02 81 00 00 00 07 45 1A 7E
7E A0 4D 21 02 21 FC 43 EB E6 E7 00 C4 02 81 01 00 00 00 08 00 36 16 01 00 02 03 0F 07 16 00 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 AA 2E 7E
9:46:57 Read object type AssociationLogicalName index: 3
7E A0 1A 02 21 21 FE 2E CB E6 E6 00 C0 01 81 00 0F 00 00 28 00 01 FF 03 00 F7 9B 7E
9:46:57 Received data
7E A0 18 21 02 21 1E 69 7C E6 E7 00 C4 01 81 00 02 02 0F 10 12 00 01 88 DA 7E
9:46:57 Read object type AssociationLogicalName index: 4
7E A0 1A 02 21 21 10 5E C5 E6 E6 00 C0 01 81 00 0F 00 00 28 00 01 FF 04 00 FF D6 7E
7E A0 22 21 02 21 30 6C 2C E6 E7 00 C4 01 81 00 02 07 11 02 11 10 12 02 F4 11 05 11 08 11 01 11 01 0F A0 7E
9:46:57 Read object type AssociationLogicalName index: 5
7E A0 1A 02 21 21 32 4E C7 E6 E6 00 C0 01 81 00 0F 00 00 28 00 01 FF 05 00 27 CF 7E
7E A0 34 21 02 21 52 A0 E3 E6 E7 00 C4 01 81 00 02 06 04 18 00 1A 1F 12 00 F8 12 FF FF 11 06 0F 00 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 03 7E
9:46:57 Read object type AssociationLogicalName index: 6
7E A0 1A 02 21 21 54 7E C1 E6 E6 00 C0 01 81 00 0F 00 00 28 00 01 FF 06 00 4F E5 7E
7E A0 22 21 02 21 74 4C 28 E6 E7 00 C4 01 81 00 02 07 11 02 11 10 12 02 F4 11 05 11 08 11 02 11 00 E2 5E 7E
9:46:57 Read object type AssociationLogicalName index: 8
7E A0 1A 02 21 21 76 6E C3 E6 E6 00 C0 01 81 00 0F 00 00 28 00 01 FF 08 00 5F 7F 7E
7E A0 13 21 02 21 96 C5 33 E6 E7 00 C4 01 81 00 16 02 B6 35 7E
9:46:57 Read object type AssociationLogicalName index: 2
7E A0 1A 02 21 21 98 1E CD E6 E6 00 C0 01 81 00 0F 00 00 28 00 00 FF 02 00 94 9E 7E
7E A0 70 21 02 21 B8 C6 47 E6 E7 00 C4 02 81 00 00 00 00 01 00 59 01 10 02 04 12 00 01 11 00 09 06 00 00 60 0A 07 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 08 FF 02 02 BC 84 7E
9:46:57 Get Next Data block:
7E A0 14 02 21 21 BA B6 AE E6 E6 00 C0 02 81 00 00 00 01 73 7F 7E
9:46:58 Received data
7E A0 74 21 02 21 DA C2 2A E6 E7 00 C4 02 81 00 00 00 00 02 00 5D 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 07 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 05 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 9D 4C 7E
9:46:58 Get Next Data block:
7E A0 14 02 21 21 DC 86 A8 E6 E6 00 C0 02 81 00 00 00 02 E8 4D 7E
7E A0 74 21 02 21 FC F6 6E E6 E7 00 C4 02 81 00 00 00 00 03 00 5D 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 03 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 02 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 FD 3B 7E
7E A0 14 02 21 21 FE 96 AA E6 E6 00 C0 02 81 00 00 00 03 61 5C 7E
7E A0 73 21 02 21 1E 36 9A E6 E7 00 C4 02 81 00 00 00 00 04 00 5C 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 06 FF F9 54 7E
7E A0 14 02 21 21 10 E6 A4 E6 E6 00 C0 02 81 00 00 00 04 DE 28 7E
7E A0 71 21 02 21 30 C2 44 E6 E7 00 C4 02 81 00 00 00 00 05 00 5A 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 D5 C6 7E
7E A0 14 02 21 21 32 F6 A6 E6 E6 00 C0 02 81 00 00 00 05 57 39 7E
9:46:59 Received data
7E A0 72 21 02 21 52 1A 19 E6 E7 00 C4 02 81 00 00 00 00 06 00 5B 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 09 16 00 00 02 03 0F 08 16 00 00 02 03 0F 07 16 00 00 02 03 0F 06 16 00 00 02 03 0F 05 16 00 00 02 03 0F 04 16 00 00 02 03 0F 03 16 00 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 0F 11 01 DB F3 7E
9:46:59 Get Next Data block:
7E A0 14 02 21 21 54 C6 A0 E6 E6 00 C0 02 81 00 00 00 06 CC 0B 7E
7E A0 74 21 02 21 74 B6 66 E6 E7 00 C4 02 81 00 00 00 00 07 00 5D 09 06 00 00 28 00 01 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 00 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 08 AF 0A 7E
7E A0 14 02 21 21 76 D6 A2 E6 E6 00 C0 02 81 00 00 00 07 45 1A 7E
7E A0 4D 21 02 21 96 1F 27 E6 E7 00 C4 02 81 01 00 00 00 08 00 36 16 01 00 02 03 0F 07 16 00 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 AA 2E 7E
9:46:59 Read object type AssociationLogicalName index: 3
7E A0 1A 02 21 21 98 1E CD E6 E6 00 C0 01 81 00 0F 00 00 28 00 00 FF 03 00 4C 87 7E
7E A0 18 21 02 21 B8 55 BC E6 E7 00 C4 01 81 00 02 02 0F 01 12 00 01 92 05 7E
9:46:59 Read object type AssociationLogicalName index: 4
7E A0 1A 02 21 21 BA 0E CF E6 E6 00 C0 01 81 00 0F 00 00 28 00 00 FF 04 00 44 CA 7E
7E A0 22 21 02 21 DA 38 64 E6 E7 00 C4 01 81 00 02 07 11 02 11 10 12 02 F4 11 05 11 08 11 01 11 01 0F A0 7E
9:46:59 Read object type AssociationLogicalName index: 5
7E A0 1A 02 21 21 DC 3E C9 E6 E6 00 C0 01 81 00 0F 00 00 28 00 00 FF 05 00 9C D3 7E
7E A0 34 21 02 21 FC D4 AF E6 E7 00 C4 01 81 00 02 06 04 18 00 1A 1F 12 00 F8 12 FF FF 11 06 0F 00 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 03 7E
9:46:59 Read object type AssociationLogicalName index: 6
7E A0 1A 02 21 21 FE 2E CB E6 E6 00 C0 01 81 00 0F 00 00 28 00 00 FF 06 00 F4 F9 7E
7E A0 22 21 02 21 1E 10 E4 E6 E7 00 C4 01 81 00 02 07 11 02 11 10 12 02 F4 11 05 11 08 11 02 11 00 E2 5E 7E
9:46:59 Read object type AssociationLogicalName index: 8
7E A0 1A 02 21 21 10 5E C5 E6 E6 00 C0 01 81 00 0F 00 00 28 00 00 FF 08 00 E4 63 7E
9:47:00 Received data
7E A0 13 21 02 21 30 F9 F3 E6 E7 00 C4 01 81 00 16 00 A4 16 7E
Thanks!
dlmsmaniac
How I could connect to the
How I could connect to the meter with Reading Key?? I need read the energy consumption, but I receive an error message. Please, can you help me?
Thanks!
In reply to Hi again! by dlmsmaniac
L+G ZCXe110CR
Your data seems to be correct and meter is not returning any error.
What error you are getting? Do you try to read meter with GXDLMSDirector or have you make own app?
dlmsmaniac
In reply to L+G ZCXe110CR by Kurumi
When I connect without Authentication, the meter do not return any error. But when I connect with authentication key, GXDLMSDirector returns the message "Referencia a objeto no establecida como instancia de un objeto." In English, "Object reference do not set as an object instance". Where is the problem??
Thanks!
We can't duplicate "Object reference do not set as an object instance" -error.
Can you send your trace that causes this error to me so we can fix it.
You'll find my contact info here:
http://www.gurux.fi/AboutUs
dlmsmaniac
Hi!
Hi!
What do you want that I send you exactly??
Thanks!
Trace log
When you get this exception send trace to me.
You can get it selecting "View Log" under Tools menu.
We can simulate your meter and fix this ASAP.
dlmsmaniac
Now, I´m getting a different
Now, I´m getting a different message:
"There are not sufficient memory to continue executing the program."
Here is the log:
Log created 11:53:40
11:53:58 Initializing serial connection.
11:53:58 Send SNRM request.
7E A0 08 02 21 23 93 B5 E2 7E
11:53:58 Received data
7E A0 1F 23 02 21 73 20 CD 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
11:53:58 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
11:53:58 Parsing UA reply succeeded.
11:53:58 Send AARQ request
7E A0 45 02 21 23 10 70 E9 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 49 42 7E
11:54:06 Received data
7E A0 08 23 02 21 35 8E 6E 7E
11:54:06 Parsing AARE reply<CR><LF>
11:54:06 Disconnect request
System.OutOfMemoryException: No hay suficiente memoria para continuar ejecutando el programa.
Trace log
Before you was using Low authentication.
Now you are using High. I believe that is the reason.
Client address or some other parameter is wrong.
Can you ask manufacturer should what High authentication they are using?
HighMD5, HighSHA1 or GMAC?
What is model of your meter?
dlmsmaniac
Hi!
Hi!
I´m using now Low Authentication. Look at the new log:
Log created 9:34:48
9:34:51 Initializing serial connection.
9:34:51 09:34:51.794 Info Opening
9:34:51 09:34:51.809 Info Serial Port Settings: Port Name: COM4 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Eop: None
9:34:51 09:34:51.809 Info Open
9:34:51 Send SNRM request.
9:34:51 09:34:51.809 Sent 7E A0 08 02 21 23 93 B5 E2 7E
9:34:51 09:34:51.887 Received 7E A0 1F 23 02 21 73 20 CD 81 80 12 05
9:34:51 09:34:51.907 Received 05 01 80 06
9:34:51 09:34:51.923 Received 00 01 53 3B
9:34:51 Received data
9:34:51 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
9:34:51 Parsing UA reply succeeded.
9:34:51 Send AARQ request
9:34:51 09:34:51.923 Sent 7E A0 45 02 21 23 10 70 E9 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 49 42 7E
9:34:58 09:34:58.925 Sent 7E A0 45 02 21 23 10 70 E9 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 49 42 7E
9:34:59 09:34:59.050 Received 7E
9:34:59 09:34:59.067 Received 7E A0 08 23 02 21 35 8E 6E
9:34:59 Received data
9:34:59 Parsing AARE reply<CR><LF>
9:34:59 Disconnect request
9:34:59 09:34:59.067 Info Closing
9:34:59 09:34:59.183 Info Closed
The manufacturer told me that meters are not using cyber security. The model is L+G ZCXe110CR.
Thanks!
Is this your meter?
http://www.prodemel.es/manuales/LANDIS_GYR_ZCXe110-manual_de_uso.pdf
We fixed "Referencia a objeto no establecida como instancia de un objeto." issue. Get latest version from GXDLMSDirector and let me know if there is something else.
dlmsmaniac
Hi!
Hi!
Yes, this is my meter. I had already gotten the latest version from GXDLMSDirector in the last log I sent you. Now, the error is OutOfMemoryException.
Besides, manufacturer have told me the client address is 2 if you want read or is 16 if you want connect as public client, but 17 is incorrect. I am not sure of this, because if I connect with client address 2, I do not receive any answer from meter, but if I connect with client address 17 I receive answer, although I receive the error too.
What do you think?
Thanks!
In reply to Hi! by dlmsmaniac
L+G ZCXe110CR
Your meter is returning Receive Not Ready. Your client address is 16 (0x10) but your server address is interesting. How you have set it? Do you have modify the source code.
It is 2 and it should be something else. Lowest bit is not set, so it should be 3.
Miko
