  3. Write Option Disabled
By Marwell , 28 December, 2015
Hello.
I've installed DLMSDirector and I can connect to my device and read many objects but the write option is disabled.
what may be caused?
Thanks.
10 years 10 months ago
There are two reason why write is disabled.
1. You you do not have permissions to write new data to the meter.
You must change authentication level from None to Low.
You can check do you have enought permissions from Logical Name or Short Name referencing view.
When you read the view you can see can you write or only read data from the meter.
2. You must change data to activate write button. Change value and press enter. Write button comes active if you have change the data.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
