  3. How Best To Simulate An Auth Meter
How best to simulate an auth meter
By murrayi , 7 March, 2023
I'm trying to use the GuruX simulator to simulate a meter with AuthenticationEncryption and HighGMac security. When specifying the `-w` wrapper parameter on the simulator I am getting `Connection permanently rejected` when I try to connect to the meter. Without using this parameter I can connect to the meter. With the meter simulated in wrapper mode, I can connect to client 16 (public client) of the meter but I can't connect using client 1 access. So it appears that there is an auth issue.
The meter I am simulating is a CLOU CL710K22.
Here is the command I used to run the simulator:
java -jar target/gurux.dlms.simulator.java-0.0.1-SNAPSHOT-jar-with-dependencies.jar -p 1024 -t Verbose -N 10 -C AuthenticationEncryption -a HighGMac -A 30303030303030303030303030303030 -T 434C500000000001 -B 30303030303030303030303030303030 -D F908F0C3030C77249AAEC381F6C5E970 -c 1 -x clou_testing.xml
