  3. Class 15 Object Return When Client Connecting With One Logical Device Through Many Communication Ports
Class 15 object return when client connecting with one logical device through many communication ports
By Gabriel Lira , 17 February, 2023
I'm exploring GURUX and all things involved in this community. But I'm also still learning DLMS/COSEM, more specifically the server model, and I have a doubt about the AA between a server and a client. So I'm doing this topic to request help =).
Whats the expected behavior of a class 15 object when a the same client, like public client, access a same logical device, like the manager, using 2 different communications ports of a physical device? (In each port, different contexts can be accordded)
Have I a way to differentiate the connections between a same client and server but in different physical networks at same time?
A answer to this question I'll help me a lot to understand how DLMS/COSEM works.
Bests Regards,
Gabriel Lira
3 years 5 months ago
Hi Gabriel, It's basically…
Hi Gabriel,
It's basically possible to establish multiple simultaneous connections, but usually, the meters allow only one connection at a time. The main reason for this is a lack of memory and CPU.
You need to create your own server for each communication port to make this possible.
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
  • mohanad
  • LOYmPGKtLNYdKy…
