  3. The Time Is Not Interrogated
The time is not interrogated
By Ingvar , 16 February, 2023
There is a counter, successfully managed to connect to it through DLMS Director and read the parameters, but my program passes the authorization, but when trying to request the time - the device does not respond.
I looked through DLMS Translator - the requests are similar.
With what can it be connected? I attach the logs at the link
https://drive.google.com/file/d/1YyCQWyIEUOiJoXmLafa_tpS9jMV5Ms72/view?…
3 years 6 months ago
HI, Your data looks right,…
HI,
Your data looks right, but because request messages are missing from the GXDLMSDirector log I can't compare them.
Have you tried to read your meter with a client example?
Ingvar
I do not have direct access…
I do not have direct access to the device, but the implementation of my driver is similar to your example.
I have attached full DLMS Director log - maybe it will help.
https://drive.google.com/file/d/1lpvBCFJaVplJbl4hbQzHm94zNS1V9k-I/view?…
Ingvar
The AARQ query in DLMS…
The AARQ query in DLMS Director has these fields:
<ConformanceBit Name="ReservedSix" />
Although the responses from the device are the same in both cases.
Could this be the problem?
