  3. HDLC Address Resolver Tool Issue
HDLC Address Resolver tool issue
By f.stojanovic , 8 February, 2023
I am having an issue with HDLC Adress resolver configuration.
I am trying to configure the settings of the COM port with the appropriate baud rate. However, the setting is frozen to COM1 (9600, 8, N, 1) setting.
Clicking OK after setting does not change the values.
Many thanks for your help.
Kind regards
Administrator
3 years 4 months ago
Hi, Thank you for pointing…
Thank you for pointing this out. This is fixed for version 9.0.2302.0901. Restast GXDLMSDirector and it's updated.
f.stojanovic
3 years 3 months ago
Hi Mikko, Thank you for your…
Thank you for your reply.
I confirm that it definitely works better, but not great still.
Basically, it works once, and the I have to uninstall and reinstall the software for it to work again. The baud rate is stuck at the setting I put initially.
Hope this helps.
Kind regards
