  3. Priority Gurux Objects DLMS/COSEM
By delanou , 23 January, 2023
Hi, I was reading the DLMS green book, where it explains priority management and says the following:
"9.1.4.4.4 Priority handling
For data transfer services using LN referencing, two priority levels are available: normal (FALSE) and high (TRUE). This feature allows receiving a response to a new request before the response to a
previous request is completed.
Normally, the server serves incoming service requests in the order of reception (FIFS, First In, First Served). However, a request with the priority parameter set to high (TRUE) is served before the previous requests with priority set to normal (FALSE). The response carries the same priority flag as that of the corresponding request. "
I have a couple of doubts:
Can these priorities be implemented in GuruX?
Who manages these priorities?
These priorities can be handled by Gurux's DLMS-COSEM objects such as a register?
Could you give me an example of how to do it?
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
