  3. Bug In Dlms C?
bug in dlms C?
By labasvakaras , 5 January, 2023
Hello, tried your dlms.c library, wanted to ask if this is a bug or I am using library wrong?
String data is trash value although data in reply is good. Scrolled through your cosem metods and saw:
cosem_setGsmDiagnostic():
memcpy(object->operatorName, value->strVal, value->strVal->size);
should'nt it be
memcpy(object->operatorName, value->strVal->data, value->strVal->size);
made a patch myself and it works.
3 years 10 months ago
I believe that you are right and thank you for pointing this out. This is released after the tests are over. I hope it's today.
labasvakaras
also, I found bug with mac
also, I found bug with mac address (octet string), that it is not printed also. Trying to find where is the problem.
EDIT: probably there is no octetstring handling, because now bb_toString returns trash values, but bb_toHexString() returns something similar what it should be.
EDIT2:
wanted to ask why there is difference in obj_getAttributeIndexToRead():
DLMS_IGNORE_EXTENDED_REGISTER is if (!((gxExtendedRegister*)object)->unit == 0)
differs from other two registers types: if (!((gxDemandRegister*)object)->unitRead)
because i get error with extended register "invalid parameter". Is this expected?
labasvakaras
any updates on this issue?
any updates on issue about extended register?
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
