  3. Disconnection Control
Disconnection control
By kevin jose minj , 22 November, 2022
For remote disconnect/reconnect how will we pass the obis code with attribute index when I pass 1&2 as attribute index it is returning logical name and output state. Any one have idea about that and I am using python library.
4 years ago
You can do it like this:
reply = GXReplyData()
dc = GXDLMSDisconnectControl()
self.readDataBlock(dc.remoteDisconnect(self.client), reply)
OR
self.readDataBlock(dc.remoteReconnect(self.client), reply)
kevin jose minj
4 years ago
In which file I have to write
In which file I have to write this code, actually I don't have much idea about this library
from gurux_dlms.object import GXDLMSDisconnectionControl
This one I already tried, is there any problem with this code?
4 years ago
You can add it for the readAll after the connection is initialized.
https://github.com/Gurux/Gurux.DLMS.Python/blob/ab0262534ee49b4d24bbf67…
Your code looks correct. Try to connect with GXDLMSDirector and use the command line arguments that you see when you select the device.
kevin jose minj
4 years ago
Thanks for your reply if I
Thanks for your reply if I code like this it will turn off the meter remotely? Instead of that it is throwing an error message
return client.method(self, 1, int(0), DataType.INT8)
File "C:\Users\HP\AppData\Local\Programs\Python\Python310\lib\site-packages\gurux_dlms\GXDLMSClient.py", line 872, in method
return self.__method(item.name, item.objectType, index, data, type_)
File "C:\Users\HP\AppData\Local\Programs\Python\Python310\lib\site-packages\gurux_dlms\GXDLMSClient.py", line 878, in __method
raise ValueError("Invalid parameter")
ValueError: Invalid parameter
4 years ago
I believe that the logical name is missing from the contructor. I didn't add it because I don't know what is logical name that your meter is using.
dc = GXDLMSDisconnectControl(LOGICAL_NAME_OF_THE OBJECT)
kevin jose minj
4 years ago
I passed logical name now its
I passed logical name now its showing access error how will I tackle that? I tried in gurux dlms director there it is accessible and disconnection also working
4 years ago
What authentication level you are using? I believe it's None. Check what you are using in GXDLMSDirector and use the same settings.
kevin jose minj
4 years ago
Authentication level is
Authentication level is present in GXDLMSDirector command line arguments
4 years ago
Is the logical name the same in GXDLMSDirector and in your app?
Have you established the connection for the meter before calling the remoteDisconnect method?
kevin jose minj
4 years ago
Logical name is correct .This
Logical name is correct .This is the code I written
def readAll(self, outputFile):
try:
#read = False
self.initializeConnection()
dc = GXDLMSDisconnectControl('0.0.96.3.10.255')
Is there any problem with code?
kevin jose minj
4 years ago
Now its working I guess the
Now its working I guess the meter is replying slowly. Thanks for your guidance
4 years ago
Thank you for letting me know. Happy coding.
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
