  3. Response Time
Response time
By kevin jose minj , 21 November, 2022
when I am passing obis code and the output will be getting after around 10 seconds.Is there any way to optimise this gurux dlms library?
4 years ago
Have you saved the association view using -o argument? If you have done it, there is nothing else to do.
Before the client can access the meter, it must establish the connection. The time depends on the speed of the communication channel and what you want to read.
kevin jose minj
4 years ago
Thank you now it is working
Thank you now it is working better than before.
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
