  3. GuruxDLMSClientExample of CPP Not Able To Use -g With Attribute Index
guruxDLMSClientExample of CPP not able to use -g with Attribute index
By ashray.a14@gmail.com , 18 November, 2022
Hi.
I am able to get all the values of my smart-meter using the C++ client and development from github when I execute with general parameters.
But when I am executing with parameter -g with Attribute index value 2
Note: This index value contains DataType of "object" with data for "Block load profile".
i.e., -g (blockloadProfileAddress):(indexValue)
FYI: -g (blockloadProfileAddress):Attribute Index works well if type is not object.
But in this case the error is:
"Error! Index: 2 read failed: Invalid parameter." In LogFile.txt.
if I execute without that parameter I am getting proper values for blockLoadProfile i.e., All the "Entries".
Without this parameter I will have to wait for a long time for meter to read all values. Need help on this I am stuck on this for many days now..!
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
